Fuel filter help!
Fuel filter help!
trying to change my fuel filter. on the bottom of the filter there is a nut for the hard line. is it reverse thread or regular? i'm going counter clockwise and that thing wont budge. please help
thanks in advance
thanks in advance
Re: Fuel filter help! (Kid1320)
its just really tight since its a flare fitting.
I would suggest using a flare wrench and then instead of pushing on it with all your might you shock it with a hammer or your hand.
It helps to keep the fuel filter bolted down so it doesn't move when you smack the wrench.
Re: Fuel filter help! (all stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock »</TD></TR><TR><TD CLASS="quote">yes - use two wrenches.
i think it's a 20mm</TD></TR></TABLE>
14mm
for future search references... make sure you screw the hard line in first before you mount the new fuel filter. i mounted it and then had to take it off because the hard line was a little too long to stick under the mounted filter.
14mm
