HELP! Tranny Drain Plug Broken
Old Oct 6, 2008 | 10:39 AM
vannak_5415's Avatar
Banned
Default HELP! Tranny Drain Plug Broken
okay i was performing a manual transmission oil change, i was checking the oil drain plug due to leaking. I checked it and it seemed okay, but when i put it back on and torqued it, it broke off...
So Im now stuck with half the drain plug stuck in the tranny drain hole and the other half is in my hand...wtf
i am now on my way to go get another oil drain plug (Password:JDM Magnetic Oil Drain Plug)...
HOW AM I SUPPOSE TO GET IT OUT?!
Old Oct 6, 2008 | 11:21 AM
honda.lioness's Avatar
Default Re: HELP! Tranny Drain Plug Broken (vannak_5415)
Good electric drill, a high strength drill bit with diameter somewhat smaller than the plug, and a tool called an "EZ Out." Autozone, Napa, Pep Boys and similar should have the EZ Out. It's not a foolproof approach, but it is where many of us start.
Of course an electric drill with a reverse feature will help. Sometimes just drilling a hole will shake a broken bolt loose.
Old Oct 6, 2008 | 01:44 PM
MR.johnson's Avatar
Default Re: HELP! Tranny Drain Plug Broken (honda.lioness)
yeah... an ez out is your friend.
Old Oct 6, 2008 | 04:48 PM
fastrc2's Avatar
Default Re: HELP! Tranny Drain Plug Broken (MR.johnson)
if the ehad is off, so there is no actual tension on the threads, then it shouldnt be tight, try staking a punch off center, and make alittle lip and drive it out that way, its hard to explain, but itll work.
Old Oct 6, 2008 | 05:34 PM
dtapia's Avatar
Default Re: HELP! Tranny Drain Plug Broken (fastrc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrc2 &raquo;</TD></TR><TR><TD CLASS="quote">if the ehad is off, so there is no actual tension on the threads, then it shouldnt be tight, try staking a punch off center, and make alittle lip and drive it out that way, its hard to explain, but itll work.</TD></TR></TABLE>
x2
E-PiLLs
Mar 28, 2013 10:39 PM
Peter_404_21
Dec 30, 2008 08:54 PM
89crx23
May 23, 2005 10:19 PM
King Tut33
May 14, 2003 04:31 PM
Mires
Sep 21, 2002 08:16 AM
