1997 Honda Accord Power Window
I have a 1997 Honda Accord and the only window that works is the driver side. I replaced the master switch and housing about two months ago when the driver window failed to operate (down only) and all was fine until last night. Now just the Driver side is working the RF, RR, LR are not working. I found a used master power switch and the same thing happened. Any suggestions?
LF Good RF Not Wking
RR Not Wking LR Not Wking
Any help is Greatly Appreciated!
Modified by owinfrey at 11:07 AM 10/6/2008
It may seem obvious but check the lockout switch on the master switch. I never use it and the other day my nephew pushed it down locking out all windows. It took me a few minutes to find the problem.
If it is not off - you could check it for continuity (ON) and infinite resistance (OFF).
Hawaii Da9
Jan 16, 2012 06:19 AM
