Cooling Fan won't turn on
Old Oct 6, 2008 | 07:43 AM
joebmx's Avatar
Default Cooling Fan won't turn on
So the car has been overheating and I know that it is partly due to a bad head gasket but also found my fan wasn't turning on. I connected it straight to the battery and it worked fine. soes this mean I have a bad relay? Can I swap it with one of the others just to check?
Thanks
Old Oct 6, 2008 | 07:58 AM
egboy94's Avatar
check ur fuse
Old Oct 6, 2008 | 08:08 AM
joebmx's Avatar
Default Re: (egboy94)
I hadn't found any bad fuses but will double check, I will swap it out as a precautionary measure.
Can someone explain what a relay does
thanks again
Old Oct 6, 2008 | 08:21 AM
Toonz08's Avatar
Default Re: (joebmx)
Essentially it's just like flipping a normal switch, only its flipping action is controlled from a remote source.
in other words its active/on when you need it and passive/off when you don't
Modified by Toonz08 at 12:01 PM 10/6/2008
Old Oct 6, 2008 | 10:20 AM
HeikDiesel's Avatar
Default Re: (Toonz08)
Unplug the connector at the fan with the car warm and see if you have source voltage. If you do, the fan is bad. If not, check the wiring.
Old Oct 6, 2008 | 10:25 AM
97ShLude's Avatar
Default Re: (HeikDiesel)
The fan switch on your thermostat housing is more than likely the culprit, unplug the connector and jump it with a piece of wire and it will make the fan run while the car is on. Its not a permanent fix but it will help until you figure out what is wrong, or you could just leave it.....it won't hurt anything
Old Oct 6, 2008 | 10:42 AM
Sean @ ESG's Avatar
Thermostat?
Old Oct 6, 2008 | 10:56 AM
97ShLude's Avatar
Default Re: (Sean @ ESG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean @ ESG &raquo;</TD></TR><TR><TD CLASS="quote">Thermostat?</TD></TR></TABLE>
Did I stutter?
Shinwasha
Feb 17, 2012 07:50 AM
EscoSi
Feb 1, 2012 06:24 AM
Eglifestyle
10
Mar 23, 2008 12:08 PM
Clutchmasta55
Mar 9, 2006 09:22 AM
THE GAME IS THICK
Feb 12, 2004 04:08 PM
