94 Honda Accord Ex Problem
Only 1 of my fans turns on and it only turns on when the air conditioning is on. I figured it must not be getting any power, but i cant find where the problem is located. Help Me Out
If you search it's been discussed a few times, usually in overheating threads.
Personally I'd wire the fans directly to the battery first, which solved my problem since I found one of the motors had burned out, replaced the fan and I was good to go.
If that's not the case could be fan relay, thermostat, etc.
Which fan doesn't turn on when you have the AC going?
the A/c uses the left, the right one isnt spinning....also smoke is spitting out of my tail pipe and my engine runs at such slow RPM's that it stalls
On your car the A/C should turn on BOTH fans.
There is a Temp switch near the T-stat that turns on the cooling fans via a relay in the underhood fuse panel, for cooling the engine.
Check for blown fuses, and as stated before try running the fans with jumper wires from the battery.
Buckethead13
Honda Civic (2001 - 2005)
Jan 31, 2019 10:41 PM
junior91hondaac
Oct 27, 2014 12:03 PM
