Help plz
Old Oct 5, 2008 | 11:15 PM
ERKK's Avatar
Default Help plz
So i put in new pisstons in my car and i put it all together and now im in limp mod so i got a new 02 sensour cuz someone said that could be it so i did still in limp mode someone help... I got a d16 a6 with a z6 vtec head ran awesome befor i put new pistons in someone help someone said ecu might be bad and i have an adjustable cam gear and i fixed some throtel response should i keep gonig and keep tweaking could that help cuz when i hit 4000rpm it back fires and ackt like i have 2 step.. some one help plzzz
Old Oct 6, 2008 | 12:17 AM
ERKK's Avatar
Old Oct 6, 2008 | 01:32 AM
traxxasx's Avatar
Default Re: (ERKK)
Check your injector plugs, if one is not on all the way it will make ur car go into limp mode.
Old Oct 6, 2008 | 09:30 AM
ERKK's Avatar
no there all in
Old Oct 6, 2008 | 02:59 PM
ERKK's Avatar
come on people
Old Oct 6, 2008 | 09:28 PM
ERKK's Avatar
Old Oct 6, 2008 | 09:53 PM
91civiccross's Avatar
Default Re: (ERKK)
Backfiring is usually the wires in the wrong spot on the distributor.
Old Oct 6, 2008 | 09:59 PM
jaypain's Avatar
Default Re: (91civiccross)
tiiiiiiiiiming.
Old Oct 6, 2008 | 10:06 PM
ERKK's Avatar
nope its dead on
Old Oct 9, 2008 | 12:57 AM
Default Re: (ERKK)
I hope you're not going by the Haynes manual, because it's wrong.
Old Oct 9, 2008 | 02:50 PM
ERKK's Avatar
ok so we checked me codes and i have 4 6 7 10 and 21
Old Oct 9, 2008 | 03:11 PM
90sedan's Avatar
Default Re: (ERKK)
Code 4 = Crank Angle sensor
Code 6 = Coolant temperature sensor
Code 7 = throttle angle (tps)
Code 10= Intake air temperature
Code 21= Vtec spool solenoid
That's some list. Make sure that all of the sensors are plugged in and are wired correctly. What else was done besides the new pistons? Obviously some wiring was done, unless you left all of those connectors unplugged.
Old Oct 9, 2008 | 05:33 PM
ERKK's Avatar
we tryed a diffrent dizzy and it didnt help at all new tps and didnt help new map sensour and nothing im confused on this
Old Oct 9, 2008 | 05:36 PM
Si-Samuri's Avatar
your best bet is to fix all the check engine codes your throwing. i believe must guys eliminate the crank angle sensor from their computer tune.
Old Oct 9, 2008 | 10:27 PM
ERKK's Avatar
wait how to u eliminate it? but iv tryed alot of **** to fix this and its pissing me off
Old Oct 9, 2008 | 11:26 PM
ERKK's Avatar
Old Oct 10, 2008 | 10:55 AM
Si-Samuri's Avatar
Default Re: (ERKK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERKK &raquo;</TD></TR><TR><TD CLASS="quote">wait how to u eliminate it? but iv tryed alot of **** to fix this and its pissing me off</TD></TR></TABLE>
i guess it is done with the same program that the custom chips are tuned with.
Old Oct 12, 2008 | 10:06 PM
ERKK's Avatar
someone help plzzz
Old Oct 13, 2008 | 08:58 PM
ERKK's Avatar
Ricrx
Nov 26, 2006 09:37 PM
ls ej1
Feb 20, 2003 01:16 PM
Drag III Integra
Dec 19, 2001 07:10 PM
