Head gasket thickness?
Old Oct 5, 2008 | 08:12 PM
suno's Avatar
Default Head gasket thickness?
I am starting a GSR turbo build. I bought my ARP head studs and now I need a head gasket.
Engine: B18C gsr motor
Plans: 57 trim turbo making around 290HP.
I hear good things about Cometic HG but what thickness should I get for my set-up?
Thanks.
Old Oct 5, 2008 | 10:52 PM
blinx9900's Avatar
Default Re: Head gasket thickness? (suno)
keep it stock, factory head gasket is more than adequate
Old Oct 6, 2008 | 03:09 AM
DaveF's Avatar
Default Re: Head gasket thickness? (blinx9900)
if your block or head is milled, you might need extra clearance for piston to head tolerances, or piston to valve, if the reliefs are not cut enough. i belive oem headgaskets are 30 thou.
Old Oct 6, 2008 | 08:14 AM
suno's Avatar
I forgot to write that since I'm going turbo I want to decrease the compression slightly with the head gasket without changing the pistons.
Old Oct 6, 2008 | 01:15 PM
DaveF's Avatar
Default Re: (suno)
call inlinepro, they sell extra thick headgaskets.
Old Oct 6, 2008 | 01:26 PM
95dxsir2's Avatar
Default Re: (suno)
mine is .074.will be around 9.3:1
Old Oct 6, 2008 | 02:13 PM
blinx9900's Avatar
Default Re: (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suno &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to write that since I'm going turbo I want to decrease the compression slightly with the head gasket without changing the pistons. </TD></TR></TABLE>
Well if its a USDM engine your stock compression is 10.0 a .050 Cometic headgasket will drop you down to 9.5 which is pretty good. But if its a JDM GSR engine the stock comperssion will be 10.6 so you will need a ~.070 to go down to 9.5.
Old Oct 6, 2008 | 02:36 PM
suno's Avatar
Yes it's a JDM gsr engine. I'm definitely going to get a cometic gasket atleast 2mm thick. Aslong as my compression goes down to the mid 9's
Old Oct 6, 2008 | 03:34 PM
blinx9900's Avatar
Default Re: (suno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suno &raquo;</TD></TR><TR><TD CLASS="quote">Yes it's a JDM gsr engine. I'm definitely going to get a cometic gasket atleast 2mm thick. Aslong as my compression goes down to the mid 9's
perfect, that should put you just under 9.5, if using cometic just user there regular head gaskets, DONT use there O-ring gasket...
Old Oct 7, 2008 | 07:21 AM
suno's Avatar
Yes I've read a post about the O-ring cometic gaskets, thanks.
I was looking online for a HG and one seller said that when using a thicker head gasket there will be a problem with the alignment of the pulleys, or something has to be adjusted....? Can someone confirm this?
Old Oct 7, 2008 | 07:36 AM
thatblkguy's Avatar
If its too thick you could throw off the cam gears but its nothing adj gears cant fix.
Modified by thatblkguy at 9:42 AM 10/7/2008
Prelude900
May 10, 2015 02:47 PM
proda9driver
Jan 9, 2008 08:23 PM
raphael
Feb 16, 2007 10:21 AM
Jason703Racing
Feb 22, 2006 06:57 PM
B00ST2nR
Aug 25, 2004 08:46 AM
