HELP SOHC
Old Oct 5, 2008 | 06:23 PM
hondaspeed305's Avatar
Default HELP SOHC
let me start over i have a 92 hatchback with a zc sohc that i am planing to put turbo i only been in the honda hobby for a month so far ive changed my ecu to a p28 and i just bought a skunk 2 intake manifold and planing to change my injector to 550cc my question is if i install them do i have to change anything else
Old Oct 5, 2008 | 06:27 PM
fryguy190's Avatar
Default Re: HELP SOHC (hondaspeed305)
well the the p28 ecu is a vtec ECU. and the ZC "stock" is non-vtec. im not shure how that will work out...
unless u have put a vtec head on there.
Old Oct 5, 2008 | 06:38 PM
ian_b16's Avatar
Default Re: HELP SOHC (fryguy190)
there is a sohc vtec zc. its the same as our z6
if you are asking if itd posible to put injectors and a IM on without changing anything else then yes. but if you plan on turbo theres alot more your gunna need to do.
a stock ecu is not gunna run a turbo car.
Old Oct 5, 2008 | 06:40 PM
fryguy190's Avatar
Default Re: HELP SOHC (ian_b16)
ok. i stand corected. i thought they where only non-vtec
Old Oct 5, 2008 | 06:41 PM
but my zc is non vtec
Old Oct 5, 2008 | 06:43 PM
ian_b16's Avatar
go to turbod16.com everthing you would need to know about turboing your d series is there.
Old Oct 5, 2008 | 06:44 PM
thanks
Old Oct 5, 2008 | 06:53 PM
koa's Avatar
koa
turbod16.com
Slobuild
Jan 7, 2013 06:14 PM
kenizzle
Oct 7, 2011 08:37 AM
Ek4drcindy
Mar 24, 2011 12:29 PM
stohc_hatch
Jun 13, 2007 07:41 PM
