sohc zc vtec
sohc zc vtec
ok, i have a sohc zc. it has a p08 vtec head on it, which is vtec. does the sohc zc come stock with vtec? and what is the best ecu to run with the setup?
Re: sohc zc vtec (stohc_hatch)
Yes, there are three JDM ZC's that were stamped with the ZC code. Two were from the prior gen of vehicles, one being a sohc non-vtec, the other being the more well known dohc non vtec 1.6. Then there was the third, which is the one you have. It's basically a D16Z6, and you can run it off of a US P28 ecu no problem.
there are actually a few more, but yeah, thats the just of it, the obd1 zc vtec is basically a JDM d16z6, and works best with a P08 ecu, but with a little knowledge a P28 can work, really depends on what car you are putting it in.
Ek Forever y0!
Re: (schardbody)
Like stated before, the stock p08 ecu will work best in stock form.
the p28 can work with a little modification and will likely be a better platform for tuning for boost later.
Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
the p28 can work with a little modification and will likely be a better platform for tuning for boost later.</TD></TR></TABLE>
i have to ask why everyone says that??? once an ecu is chipped for boost with any program its basically a generic ECU, the program determines everything, not the actual inner workings as they are all the same basically, with the exception of a few emissions components.
i keep seeing people say get a P28, its best for boost, or its easiest to chip, or something like that, it makes no sense.
Ek Forever y0!
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">
i keep seeing people say get a P28, its best for boost, or its easiest to chip, or something like that, it makes no sense.</TD></TR></TABLE>
It has to be what everyone and their mom uses for some reason...
Though I totally agree with you on them all being similar/identical once chipper/tuned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">It has to be what everyone and their mom uses for some reason...
Though I totally agree with you on them all being similar/identical once chipper/tuned.</TD></TR></TABLE>
its what everyone uses because thats what everyone keeps saying is best, so people grab em, because they know they can charge more for them. even a p05 ecu once chipped, if vtec is added, and converted to manual if necassary, is gonna be IDENTICAL to a P28.
SoullessJapaneseMachine
27
12-04-2006 06:46 PM
