y8 oil pumps
Old Oct 5, 2008 | 06:11 PM
Chris_Spires's Avatar
Default y8 oil pumps
hey guys i just started up an account on here and i love all the help and information given here. i was wondering if someone could help me out with what kind of oil pump does well with turbo setups and where i can find them for sale.
Old Oct 5, 2008 | 06:45 PM
ke98248's Avatar
Default Re: y8 oil pumps (Chris_Spires)
A new stock one should work alright... I've used my stock one (never changed) on my turbo d16y8 for 9 months now.. no problems..
Old Oct 5, 2008 | 06:52 PM
koa's Avatar
koa
Default Re: y8 oil pumps (ke98248)
Ive read about a shimming mod. to the y8 oil pumps. its done for extra reliabilty
Old Oct 5, 2008 | 07:14 PM
1fastsi's Avatar
Y-series bottom ends have bad oiling for performance. They just produce low numbers.
D16A6 Oil pump flows 46.4 qt/min@6250rpm
D16Z6 Oil pump flows 47.6 qt/min@6000rpm
D16Y8 Oil pump flows 35.3 qt/min@6800rpm
Here are some numbers...you can see the Y-series oil pump flows SIGNIFICANTLY LESS oil and it's also spinning at the highest RPM as well. Generally/theoretically speaking, the faster you spin the pump, the more oil it pumps. Well it's spinning faster then the rest and it's flowing a lot LESS oil.
IMO I'd steer clear of the Y8 oil pump unless its been modded as stated above.
Old Oct 6, 2008 | 03:34 PM
thanks to the 3 responses. i knew the y8 was the worst of the d-series oil pumps and as of right now that's what i think gave out on my 1st turbo setup. (which is why i'm now looking for the better/more reliable pump)
another question, is the z6 pump compatible with a y8 block? i know in almost all respects that parts for the d-series are nearly identical(if they aren't identical) but for instance the oil pans for the z6 don't match perfectly on a y8 block... is this a similar issue with the oil pump or can you interchange them?
slob20ef
Sep 9, 2009 05:36 PM
88turdbucket
Dec 20, 2008 10:27 AM
eg8tuner
Apr 26, 2007 02:02 PM
infinatenexus
Feb 7, 2004 01:12 AM
