95 civic si coupe stock, what to do?
Old Oct 5, 2008 | 05:47 PM
C00kiemunstr's Avatar
Default 95 civic si coupe stock, what to do?
Ok, well i thaught i would just ask. Its a 95 civic si coupe, 1.6 v-tech, automatic (wish it was a manual). What would be the first thing or possibly the cheapest thing that will make the car more responsive/faster.
And has anyone done a head gasket on this car? I think i might have to eventually do one. Hopping not, crossing fingers. I was just curious as how bad of a job it could be.
Thanks
Old Oct 5, 2008 | 05:55 PM
dvlsfan30's Avatar
if you do the work yourself it wont be bad if you know what your doing.
better off just swapping in a motor that is a standard and work from there.
Old Oct 5, 2008 | 05:57 PM
How much of a job is it to convert from a automatic to a manual?
Old Oct 5, 2008 | 06:01 PM
slowhitEJ1's Avatar
to my knowledge, unless there has been something revealed over the past couple months or so, there's no such thing as an si coupe.. if you wanna keep the D, check into what it would take to put in a manual.. as far as making it faster, some will say B swap, some will say turbo the stock motor, but either way, i believe everyone is going to say to get rid of the auto..
Old Oct 5, 2008 | 06:03 PM
well the back of the car says coupe si and its a 95. So how bad are these automatics?
Old Oct 5, 2008 | 06:06 PM
RagnarX's Avatar
Default Re: (C00kiemunstr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C00kiemunstr &raquo;</TD></TR><TR><TD CLASS="quote">well the back of the car says coupe si and its a 95. So how bad are these automatics? </TD></TR></TABLE>
The automatics suck pretty bad. I use to drive one, converted it to manual and will never go back. the Swap wasn't too hard, but getting the pedal assembly out and in was a real bitch.
Old Oct 5, 2008 | 06:09 PM
fryguy190's Avatar
Default Re: (slowhitEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhitEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">to my knowledge, unless there has been something revealed over the past couple months or so, there's no such thing as an si coupe.. if you wanna keep the D, check into what it would take to put in a manual.. as far as making it faster, some will say B swap, some will say turbo the stock motor, but either way, i believe everyone is going to say to get rid of the auto.. </TD></TR></TABLE>
acctuially there is sutch thing as a 95 Si Coupe. just not in the states...
there Si is equvlant to our EX.
Old Oct 5, 2008 | 06:13 PM
fryguy190's Avatar
Default Re: (RagnarX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagnarX &raquo;</TD></TR><TR><TD CLASS="quote">
The automatics suck pretty bad. I use to drive one, converted it to manual and will never go back. the Swap wasn't too hard, but getting the pedal assembly out and in was a real bitch.</TD></TR></TABLE>
yes i will deffinetly vouge for that. i helped a buddy of mine do that swap. b/c the shop wanted to charge him $700. but i have been supprized by a automatic that had some kick to it. but a conversion to a standard is better once u get ur shift points down.
interesting, i did not know that. So how exactly does the auto suck. In terms of power or in terms or reliability? I just baught the car 5 hours ago. $1000, 248,000km, a/c great body. questionable head gasket, (found after we got it home) i thaught it sounded like an ok price. not looking for a high performance car jsut something that works and gets me around, and can have fun in.
eg_boi's Avatar
Default Re: (fryguy190)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fryguy190 &raquo;</TD></TR><TR><TD CLASS="quote">
there Si is equvlant to our EX. </TD></TR></TABLE>
x2 Canadian civics si=usdm civic ex
canadian sir=usdm 99-00 si
Old Oct 5, 2008 | 06:17 PM
fryguy190's Avatar
Default Re: (eg_boi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_boi &raquo;</TD></TR><TR><TD CLASS="quote">
canadian sir=usdm 99-00 si</TD></TR></TABLE>
EJ2NigB
Appearance Build Threads
May 11, 2015 03:14 PM
dc5itracer
Honda Civic (2001 - 2005)
Jan 26, 2014 05:43 AM
artwiggins
Jul 26, 2009 05:31 AM
Aarron_M
Feb 2, 2006 04:03 AM
Nocturnal
Sep 11, 2005 06:10 AM
