Shift linkage issue in 94 Del Sol HELP!!
Old Oct 5, 2008 | 05:34 PM
jdm_eg's Avatar
Default Shift linkage issue in 94 Del Sol HELP!!
ok heres the problem. I have a 94 honda del sol vtec which orginally came with a b16 in it. Now i blew the motor in it and the b16 is no longer good, so i swapped in a d16z6. everything is in and bolted up plugged and ready to go but one thing, the shift linkage. i got a shift linkage with d16z6 swap which is supposidly a d series shift linkage. But the problem is that, that shift linkage is to short and will not go into the cabin area to bolt up. it is a 2 3 inches to short. I tried mocking up the b16 shiftlinkage and that is way to long. I dont no if the vtec model has anything to do with it?
so basically my question is shouldnt the d series shift linkage bolt right up no problem? or since its the b16 model its diff. but i thought that they are interchangeable.
Old Oct 5, 2008 | 05:43 PM
geebs's Avatar
Default Re: Shift linkage issue in 94 Del Sol HELP!! (jdm_eg)
i think the del sol had its own speical shift linkage.. not 100% positive..
you could go to like slhondaparts.com and compare the part numbers..
Your vehicle -> shift linkage vs like 95 Civic EX shift linkage..
Old Oct 6, 2008 | 12:39 PM
jdm_eg's Avatar
thanks yup the linkage on a 95 civic is about 2 inches shorter then a del sol linkage. for some reason the del sol linkage is alil longer then a civics. thanks geebs
Old Oct 6, 2008 | 12:51 PM
Nbboy7's Avatar
need to be a del sol vtec shitlinkage
Rez93del
Feb 22, 2017 07:23 PM
b16delsolnewb
Apr 1, 2008 05:31 PM
BRG+Honda=JDM
Jun 22, 2007 11:25 PM
unstopabledj
Jul 1, 2003 02:30 PM
skellator_thoj
Jul 16, 2002 07:57 PM
