Who makes/sells the freeze plug threaded fittings with -10an ports..?
That $60 from T1 is for the pair, so its really not bad at all..
Z10 only makes them in -12AN, T1 has them in -10, which is much more common.. B&R just knocked off Tony's part, so I'd support Tony!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash »</TD></TR><TR><TD CLASS="quote">That $60 from T1 is for the pair, so its really not bad at all..
omg and they both knocked off Z10
honestly B&R did NOT knock off tonys part, it is a common idea, if there was an issue there would be a patent but you cant patent common knowledge
. honestly B&R did NOT knock off tonys part, it is a common idea, if there was an issue there would be a patent but you cant patent common knowledge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smoovy »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/2020423 here you go.</TD></TR></TABLE>
i think you mean:
https://honda-tech.com/zerothread?id=2239293
i think you mean:
z10 came out with it first...br fittings made them before tony's cnc pieces although I believe tony has been welding them for a while as well. I made some too but I don't do them on a mass production scale and mine are only welded. I won't lie, I saw what z10 did a while back and made some of my own.
Ya it got old drilling them out and welding them. So we got some CNC machined. We've had the CNC machined ones for 8 months now.
If you can support your H-T sponsors.
