2000 Civic Si issue w/ pass. window switch.
I'm having an issue with my passenger side power window after having my windows tinted last month. The original motor was getting very slow, so I figured it simply died.
So I bought a new window regulator motor from the dealer thinking this was the problem. Removed everything with no problems and installed the new motor. Got it installed and hooked it up to the switch - nothing. Checked the fuse for the umpteenth time - good.
Anyone run across this problem on their Civic/Del Sol and have an idea of where to look further? Relay maybe? I can't imagine the new motor is bad.
Anyone have a wiring diagram available to save me a trip to the dealer?
Oh and yes, the drivers side works fine.
Thanks,
Thanks,
Does the window motor connector get power when you push the switch. If so, the window may be binding in the window side channels in the door. Start by spraying some silicone lubricant down the rubber side channels with the window rolled down.
bighoss77
Aug 16, 2012 08:44 PM
