It took me a long time but my EJ1 fired for the first time today
well its been a long time coming but my EJ1 is finally running again with a solid rebuilt Z6. I was just a little curious on what you guys do to break in your motors
It was me first time to remove an engine and rebuild it was well worth the end result
I'm under the impression a lot of people use non-detergent ($1/quart crap at supermarkets) oil for a few miles, change it, repeat etc... That's for the piston rings. It's considered "necessary", but varies depending on piston.
http://www.google.com/search?q...eakin has more information than I can provide. But it's definitely something to consider.
Edit: vvvvvvvvvvvvvvvvvvv Ah, I see. I'm at a blank there.
Modified by Davus at 1:51 AM 10/5/2008
take it slow for the first 3,000 miles.. meaning no vtec or anything stupid like that.. after 3,000 ocassionally hit vtec once and then calm down again. also get a magnetic drain plug for your oil pan..
Here's my short list
let engine idle about 1500rpm for the first 20 minutes, shut off change oil and filter
drive car for 500 miles no long WOT only short burst of rpm
Hint, check to make sure all external bolts are still tight.
change oil and filter at 500 miles
drive car for 1000 miles, no very long WOT, change oil & filter
drive car for 1500 miles change oil and filter.
Now drive it like you stole it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si »</TD></TR><TR><TD CLASS="quote">Here's my short list
Now drive it like you stole it...</TD></TR></TABLE>
this is a good sufficient way. i would just ad a valve lash check at 500 and cut open your oil filters for the first couple changes
drumminforev
286
Jul 1, 2012 04:01 PM
1fast90civicsi
Nov 13, 2007 06:17 PM
Egodestruct
Jun 11, 2004 01:55 PM
RedRacerCivic
Dec 2, 2003 10:36 PM
