how do u put a air fuel ratios on civic coupe
Old Oct 4, 2008 | 04:46 PM
aLlmoTorcoUpe's Avatar
Default how do u put a air fuel ratios on civic coupe
hi i want to know how can i find a way to put a air fuel ratio on. the car is a 93 civic coupe ex. and i been asking people around to help but it doesn't seened like they know. if anyone knows can i get some help on it.
Old Oct 4, 2008 | 08:07 PM
98vtec's Avatar
moderator emeritus
Default Re: how do u put a air fuel ratios on civic coupe (aLlmoTorcoUpe)
it would help to know which wideband you are wanting to install.
Old Oct 4, 2008 | 09:24 PM
Default Re: how do u put a air fuel ratios on civic coupe (98vtec)
all i know is just the ground wire but the other one i don't i know their is a black, red and purple. if u can help me out with it
Old Oct 5, 2008 | 12:58 PM
azeez's Avatar
- red for positive
- black for negative
- purple for 02 sensor
Old Oct 5, 2008 | 10:50 PM
PRIMITIVEALLMOTOR's Avatar
Default Re: how do u put a air fuel ratios on civic coupe (azeez)
which wire from the O2...
Old Oct 5, 2008 | 11:59 PM
david974's Avatar
Default Re: how do u put a air fuel ratios on civic coupe (PRIMITIVEALLMOTOR)
D14 pin on OBD1 ecu
Old Oct 6, 2008 | 10:46 PM
Default Re: how do u put a air fuel ratios on civic coupe (david974)
which wire from the o2. i know that the o2 has 4 wires but only one wire is right to able to work. i just need the right wire from the 02.
Old Oct 7, 2008 | 02:53 AM
inspector01's Avatar
Wire it to pin D14 on the ecu, not that it will matter if you get it right, anything with changing voltage will give you the light show you want....
Old Oct 7, 2008 | 08:59 PM
Default Re: (inspector01)
i'm sorry i don't know the d14 is. can ya show me or tell what the d14 is.
Old Oct 7, 2008 | 09:23 PM
98vtec's Avatar
moderator emeritus
Default Re: (PRIMITIVEALLMOTOR)
http://technet.ff-squad.com/wiring.obd1.htm
Old Oct 7, 2008 | 10:29 PM
Default Re: (98vtec)
okay thanks i got it now
Old Oct 11, 2008 | 05:31 AM
laziebun's Avatar
i dont think thats a wide band. I think you have a narrow band and which IMO sucks.
Old Oct 12, 2008 | 10:49 AM
Default Re: (laziebun)
so wat do u mean about narrow n wide band
Old Oct 12, 2008 | 11:06 AM
98vtec's Avatar
moderator emeritus
Default Re: (aLlmoTorcoUpe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aLlmoTorcoUpe &raquo;</TD></TR><TR><TD CLASS="quote">so wat do u mean about narrow n wide band</TD></TR></TABLE>
its a light show that doesnt tell you anything beyond that you are richer or leaner than stoich.
go read on wikipedia about a wideband o2 sensor and a narrowband o2 sensor.
skip122
Apr 22, 2006 04:00 PM
Aaron M
Jun 7, 2005 06:24 PM
SRCivic97
Oct 14, 2004 07:43 AM
Tony the Tiger
Oct 24, 2001 09:38 AM
