Got a 99 Civic VP - Suggested Maintenance?
Old Oct 4, 2008 | 04:14 PM
CPTN's Avatar
Default Got a 99 Civic VP - Suggested Maintenance?
Hey all,
I bought a 99 Civic VP today with 106k on it. The timing belt and water pump were changed at 95k, I have service records for that, by Honda. I'm taking her on a road trip Saturday, about 700 miles round trip. What basic maintenance should I do first? I'm already thinking some basics - air filter, spark plugs, oil, etc.
Also, is it to late to switch to synthetic oil?
Old Oct 4, 2008 | 04:49 PM
Civic_1337's Avatar
Default Re: Got a 99 Civic VP - Suggested Maintenance? (CPTN)
yeah you thought of most of it. and make sure you bring your jack and everything needed to slap on the full sized spare you should bring/
Old Oct 4, 2008 | 04:56 PM
Historyg's Avatar
I would just stick with bulk oil, it has a 100k on it already you might as well not go synthetic
K&N drop in filter
ignition wires
distributor cap
ignition rotor
four spark plugs
fuel filter
oil filter
PCV valve
PCV valve grommet
Bulk Oil 10w 30 or 5w 30 depending on Temperature
Check and service brake pads replace if needed with your choice of brakes and rotors
You dont have to worry about coolant since he did the timing belt and water pump since they should have had to drain your coolant for that job
Add some Lucas fuel injector cleaner in the gas tank And fill it up, I suggest Lucas only the others are crap thats just my opinion
Balance and rotate your tires replace any if thread is below threshold
And thats about it, should take you a long while on that, probably through The us.
Old Oct 4, 2008 | 05:14 PM
CPTN's Avatar
Awesome, thanks guys!
KrazyDawg
Mar 18, 2008 04:39 PM
Vaw7er
Mar 3, 2007 07:18 AM
goowakjai
Jul 15, 2005 10:29 PM
alfaaay
Mar 16, 2004 09:54 AM
ieatrice
13
Jan 27, 2004 12:02 PM
