Best turbo pistons
Old Oct 4, 2008 | 03:39 PM
EJ8 GSR-T's Avatar
Default Best turbo pistons
Greetings, I have a b18 block, bored to 84mm with darton sleeves and i need some pistons to go with. I previously had cp pistons but they seemed to crack abit over a 15k mile period which makes me a little nervous to get more. The car is a dd and i dont expect over 300-350hp. Any recommendations on some that will last?
Old Oct 4, 2008 | 03:54 PM
tony413's Avatar
Default Re: Best turbo pistons (EJ8 GSR-T)
SEARCH DAMNIT
but my bias is toward arias in 84mm or wiseco in 82mm
Old Oct 4, 2008 | 04:05 PM
rmcdaniels's Avatar
If your CP's cracked, then you need to find out why that happened before you put another set of pistons in the motor.
Old Oct 4, 2008 | 05:15 PM
ITR-EKcoupe's Avatar
Default Re: Best turbo pistons (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">If your CP's cracked, then you need to find out why that happened before you put another set of pistons in the motor.</TD></TR></TABLE>
i agree
Old Oct 4, 2008 | 07:44 PM
fastcody1's Avatar
Default Re: Best turbo pistons (ITR-EKcoupe)
JE all the way
Old Oct 4, 2008 | 08:25 PM
boostismycrack's Avatar
E-thug
Default Re: Best turbo pistons (fastcody1)
JE
Old Oct 4, 2008 | 09:51 PM
blinx9900's Avatar
Default Re: Best turbo pistons (boostismycrack)
CP's where cracking left and right back in the day, there was a known defect near in the valve relief area... If this is the problem the OP was having its somewhat normal for the older CP's...
Old Oct 4, 2008 | 09:56 PM
Eklsv-t's Avatar
Default Re: Best turbo pistons (blinx9900)
i have wiseco's in my ls vtec and boosting 15psi daily
Old Oct 4, 2008 | 10:54 PM
voodoo on 23s's Avatar
if its a dd and you dont expect to make over 300hp, why dont you just get a fresh stock bottom end or whole motor. they go for about the same price as forged pistons
Old Oct 5, 2008 | 02:59 AM
SD_Lurker's Avatar
HT White Ops
Default Re: (voodoo on 23s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voodoo on 23s &raquo;</TD></TR><TR><TD CLASS="quote">if its a dd and you dont expect to make over 300hp, why dont you just get a fresh stock bottom end or whole motor. they go for about the same price as forged pistons</TD></TR></TABLE>
Now why would he do something like that? He has a bottom end that already has Darton Sleeves. That would be idiotic, plain and simple. Invest in some pistons and some good rods and the bottom end will be pretty much bullet proof. CP gets my vote. As stated previously, CP did have issues with their pistons regarding the valve reliefs. It was a very thin section and over time the side of the valve relief would crack off. Anyway, CP, Wiseco, JE are all GREAT pistons.
Old Oct 5, 2008 | 03:19 AM
blinx9900's Avatar
Default Re: (SD_Lurker)
Ross and Supertech are good too
Old Oct 5, 2008 | 10:22 AM
tony413's Avatar
Default Re: (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">Ross and Supertech are good too </TD></TR></TABLE>
i like ross pistons as well i use them on domestics and evo's but i haven't seen anyone have success with them on honda's
Old Oct 5, 2008 | 01:22 PM
azeez's Avatar
Default Re: (tony413)
I think Ross is the best
Old Oct 5, 2008 | 02:11 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">but i haven't seen anyone have success with them on honda's </TD></TR></TABLE>
You make it sound like you have seen people have failure with Ross pistons on Honda's, is that the case or am i reading too much into what your saying?
Old Oct 5, 2008 | 02:18 PM
smoovy's Avatar
Default Re: (azeez)
I'm currently using Ross. fully built sleeved running Pauter rods. when I was looking for pistons, I looked at Wiseco, CP, and Ross.... is JE really any good? not to sound like a noob, I was always told to look elsewhere for forced induction.
Old Oct 5, 2008 | 02:29 PM
non-VTEC's Avatar
Default Re: (smoovy)
JE here.......i wont run anything else other than JE from now on........well perhaps arais......
Old Oct 5, 2008 | 04:20 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: (non-VTEC)
never had any problems with my CPs, go with your first instinct you had before you had that problem and again, check to see what caused that problem too.
Old Oct 5, 2008 | 04:42 PM
blinx9900's Avatar
Default Re: (JDM turbo DC)
pistons are to engine builders what EMS is to tuners, everybody is good at there own thing and few are good with all of them.
a lot of engine builders swear by JE, some can never get them right. I would pick my piston based on what my engine builder prefers just like i would chose my EMS based on what my tuner prefers
Old Oct 5, 2008 | 04:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">I would pick my piston based on what my engine builder prefers just like i would chose my EMS based on what my tuner prefers </TD></TR></TABLE>
everyone has there preferences and experiences so that is definitely the best advice
Old Oct 5, 2008 | 05:01 PM
tony413's Avatar
You make it sound like you have seen people have failure with Ross pistons on Honda's, is that the case or am i reading too much into what your saying?</TD></TR></TABLE>
no you're reading it exactly right. i have seen more people have not so good experiences with ross pistons in hondas because of USER ERROR mostly. and some occasional piston slap
Old Oct 5, 2008 | 05:58 PM
EJ8 GSR-T's Avatar
With regards to CR. I had been advised to use 9:1, whats the best way to go about deciding which ratio will work the best? Would 10:1 help spool faster? Get some more power lower down? Or would that be too much?
Old Oct 5, 2008 | 06:15 PM
tony413's Avatar
Default Re: (EJ8 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">With regards to CR. I had been advised to use 9:1, whats the best way to go about deciding which ratio will work the best? Would 10:1 help spool faster? Get some more power lower down? Or would that be too much?</TD></TR></TABLE>
9:1 or 8.5:1 is perfectly fine
10:1 is ok but you are more limited on the amount of boost you run because of heat and cylinder pressure
Old Oct 5, 2008 | 10:56 PM
blinx9900's Avatar
no you're reading it exactly right. i have seen more people have not so good experiences with ross pistons in hondas because of USER ERROR mostly. and some occasional piston slap </TD></TR></TABLE>
wow, pretty shocked... would the slap not also be user error? I know the evo guys are loving these pistons and ive been to Ross HQ here in socal, good guys, they are very open to engine builders opinions on there pistons to help better the design, they will work close with most builders to get them what they want...
back on topic though, i agree 8.5-9.0 is great, i personally run 8.3:1, its just what i ended up with, off boost driving is fine, spool up is fine
94civicgsr
Feb 4, 2008 09:27 PM
superturboprelude
Oct 2, 2007 03:03 AM
cigrafix2
Jul 3, 2007 06:46 AM
Ding
Aug 12, 2005 08:26 AM
CiViC SiR
Oct 4, 2003 12:35 PM
