Transmission & Drivetrain Gearboxes, Differentials, Clutches
stage 4 competion clutch problem need help buts fast
Old Oct 4, 2008 | 02:17 PM
tortuga89's Avatar
Default stage 4 competion clutch problem need help buts fast
hello guys i am new in here son my question to u guys is
that i install a cc stage 4 into ,y crx and wound go in gear only when the car is off i try to adjusted but did not work so please guys can you help i do not know what to do
thakns
Old Oct 5, 2008 | 05:43 PM
skippygsr's Avatar
Default Re: stage 4 competion clutch problem need help buts fast (tortuga89)
stay away from comp clutchs went threw 4 in a year pressure plates are garbage
Old Oct 5, 2008 | 07:29 PM
bad ferio's Avatar
make sure your throw-out bearing is still connected to the fork.
Old Oct 10, 2008 | 05:34 AM
Boosted_B_Series's Avatar
Default Re: stage 4 competion clutch problem need help buts fast (skippygsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skippygsr &raquo;</TD></TR><TR><TD CLASS="quote">stay away from comp clutchs went threw 4 in a year pressure plates are garbage </TD></TR></TABLE>
I find this very hard to believe. I guess your a ACT supporter huh.. Maybe you should learn how to drive or learn how to turn wrenches.
Comp clutch has a very good reputation and their clutches are proven. Period.
This situation and the op situation both seem like an incorrect installation..
Old Oct 13, 2008 | 07:46 PM
skippygsr's Avatar
Default Re: stage 4 competion clutch problem need help buts fast (Boosted_B_Series)
[QUOTE=Boosted_B_Series]
This situation and the op situation both seem like an incorrect installation.. [/QUOTE dont care what u say i wrench on my own **** since i was 15 so lick my ********* and you are a tool
Old Oct 13, 2008 | 07:52 PM
skippygsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_B_Series &raquo;</TD></TR><TR><TD CLASS="quote">
This situation and the op situation both seem like an incorrect installation.. </TD></TR></TABLE>
by the way can u pull 1.5 60ft wit 23in slicks on 475 hp yea didnt think so so dont tell me i cant drive act for the win always
Old Oct 15, 2008 | 10:03 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
I would suggest that you either call us in the office or allow a local shop to take a look. Sometimes it's about adjustment and sometimes you can have failing components like a slave that's stuck or bad.
Also, do feel free to give us a call and we'll set something up for you.
Chris H.
Competition Clutch
Old Oct 15, 2008 | 10:04 AM
Wow, sorry to hear that. Did you call us and let us know?
Chris H.
Old Oct 15, 2008 | 11:03 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: stage 4 competion clutch problem need help buts fast (Richard Noggin)
10 bucks says it's hydro issue or the disc is backwards
Old Oct 15, 2008 | 07:31 PM
skippygsr's Avatar
Default Re: stage 4 competion clutch problem need help buts fast (Evs-One)
not talking bout disc...the pp fall i got the same comp clucth 6puck disc on a act pp with 50k on it out of my daily and it had no prob holding power with the act pp and comp clutch disc it really nice think gunna stick with act pressure plate
Old Oct 17, 2008 | 11:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skippygsr &raquo;</TD></TR><TR><TD CLASS="quote">not talking bout disc...the pp fall i got the same comp clucth 6puck disc on a act pp with 50k on it out of my daily and it had no prob holding power with the act pp and comp clutch disc it really nice think gunna stick with act pressure plate</TD></TR></TABLE>
Like I said, you should call and let us help you....
Old Oct 17, 2008 | 11:15 AM
Evs-One's Avatar
Solbros Owns Me
if you wrench as good as your write...you're in trouble
Old Oct 20, 2008 | 09:18 PM
skippygsr's Avatar
yea not so good at spelling
wastedyouth2542
Jul 2, 2008 02:20 PM
94delslo
Mar 28, 2008 08:48 PM
litovi3tboi503
Apr 27, 2007 09:27 AM
jamartin0519
Jan 12, 2006 06:29 AM
95jeremie
10
Feb 23, 2005 08:42 AM
