Wiring in Obd1 Inj
Old Oct 4, 2008 | 01:26 PM
88todab16crx's Avatar
Default Wiring in Obd1 Inj
I have a 88 crx with a b16a swap obd1 converted. I need to know how to wire in the obd1 inj i have the corresponding clips to wire them in and i need to know how to get rid of the fuel resistor box to thanks
Old Oct 4, 2008 | 05:54 PM
HandofBoB's Avatar
New User
Default Re: Wiring in Obd1 Inj (88todab16crx)
the yellow/black wire that goes to the resistor box goes directly to the other four positive leads. Think they are red/black. Go to rywire and click on his obd0-obd1 conversion how to and read the part about injectors. Hope this helps.
Old Oct 4, 2008 | 06:41 PM
Default Re: Wiring in Obd1 Inj (HandofBoB)
Thanks I will go right now
Old Oct 4, 2008 | 11:33 PM
D16SiHatch's Avatar
that sounds confusing. heres the steps to remove the box. well first you uh unplug the box and toss it aside. then take all 5 wires that come into the green resistor box harness plug (4 yellow,1 red) and solder them together. seal up the connections and wrap some electrical tape snuggly around the whole bundle. thats all you have to do
Old Oct 5, 2008 | 08:27 AM
Default Re: Wiring in Obd1 Inj (D16SiHatch)
Now I need to cut the obd0 inj plugs out and then wire the obd1 inj plugs into the harness does anyone know a write up or how on that
Old Oct 5, 2008 | 05:22 PM
D16SiHatch's Avatar
its just 2 wires..
hedtrip
Apr 28, 2006 08:00 PM
SupraRXZ
Feb 5, 2006 06:57 PM
gt35r
May 16, 2005 11:40 AM
turbox
Feb 13, 2005 10:22 PM
fffrog
Feb 3, 2004 04:10 PM
