OEM rings on CP pistons?
Old Oct 4, 2008 | 10:26 AM
Clerique's Avatar
Default OEM rings on CP pistons?
I'm rebuilding my engine so I got all new OEM seals, bearings and piston rings.
Then I got some used mint 81mm CP pistons at a good price.
Quick question: can I use the OEM rings on the CP pistons without a problem?
Old Oct 4, 2008 | 10:45 AM
non-VTEC's Avatar
Default Re: OEM rings on CP pistons? (Clerique)
maybe the oil rings and second ring. but i do believe the top/compression ring is thicker on the factory piston.
forged pistons typically run 1.0mm thick top rings.
OEM pistons are typically 1.2mm thick top rings.
Old Oct 4, 2008 | 10:56 AM
DonF's Avatar
Default Re: OEM rings on CP pistons? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">maybe the oil rings and second ring. but i do believe the top/compression ring is thicker on the factory piston.
OEM pistons are typically 1.2mm thick top rings.</TD></TR></TABLE> Only on the B20, and not all of those. You do need to check the ring to groove gap.
Old Oct 4, 2008 | 02:40 PM
Clerique's Avatar
Default Re: OEM rings on CP pistons? (DonF)
That's good to know. Thanks!
Also, the OEM rings I bought are different from the ones I pulled out of the old pistons, the oil ring that is.
Top is new OEM, Right is Old OEM and Left is Old CP.
Notice how the new rings' 'ripples' are oriented differently.
Comments?
BTW the car is a '96 JDM Integra Type R
Old Oct 4, 2008 | 03:32 PM
DonF's Avatar
Seeing as Honda and CP do not make rings, you need to figure out who they were buying from at the time. Different manufactures use different styles.
Old Oct 4, 2008 | 05:14 PM
mar778c's Avatar
Community Builder
Community Influencer
You can order the rings from CP.
b20beast83
Apr 22, 2010 09:32 AM
quik1
Jun 19, 2004 06:33 PM
quik1
Jun 9, 2004 07:48 PM
hybridEj6
Apr 15, 2003 07:50 PM
