Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Interior dash dimmer wire color code
Old Oct 3, 2008 | 09:07 PM
super civic's Avatar
Default Interior dash dimmer wire color code
Im trying to figure out which color the dimmer wire is so i can wire in guages. its a 06 civic 1.8 coupe any insight would be cool. thanks for any help.
Old Oct 3, 2008 | 09:51 PM
i-VTEC_DOHC's Avatar
pull out your dimmer switch and look at the color of the wire??
Old Oct 6, 2008 | 06:54 AM
Default Re: (i-VTEC_DOHC)
there are five wires in the receptical for the dimmer including mph/km trip A trip B and oil life, id hate to start cutting and splicing. and i cant seem to find a Honda schematic online either of which would be great
Old Oct 7, 2008 | 07:16 PM
Echo7847's Avatar
Default Re: (super civic)
Should have power @ each wire in the connector.
Led bulb's power wire is @ pin 5 the grey wire, lit in park/on position.
Use a scotch-lock instead of creating a break in the wire. Verify this wire will work with a multi-meter before you tap into it. Power and ground are controlled by the multiplex but the ground side of the led is a red wire.
Modified by Echo7847 at 11:21 PM 10/7/2008
Old Oct 9, 2008 | 07:48 AM
Default Re: (Echo7847)
Echo 7847 thanks for the post i just wired it up. good looking out
xunkn0vvnx
Aug 2, 2007 07:45 PM
JDMlyfestyle
19
Feb 4, 2005 07:51 PM
Hatch It
Jun 8, 2004 07:33 AM
Trigun
Apr 18, 2002 03:26 AM
