Spacers and Nuts
Old Oct 3, 2008 | 08:49 PM
ceph's Avatar
Default Spacers and Nuts
Hi,
I bought some new wheels and found out I needed spacers because the front wheels were rubbing against the brake caliper.
So I bought some spacers and lug nuts for that. Now, I have a problem with attaching the spacer to the car.
The honda studs stick out past the spacer so I figure I would cut them down to make it flush with the spacer however, the honda lug nuts would be sticking out as well.
My friend who worked on my wheels suggested I get some regular nuts for honda studs. Not lug nuts. So I went to my local hardware store and the thread style on their nuts are half an inch.
I think I need nuts with threads that are 1.5 inches. I am not sure though and am not sure where I can find such a thing. Please help.
I just need some nuts that are small enough to fit through the holes of the spacer to fit on the studs of my car.
Old Oct 4, 2008 | 05:06 PM
alphalanos's Avatar
Default Re: Spacers and Nuts (ceph)
What kind of spacer did you get. Some such as Project Kics bolt onto the existing studs with countersunk nuts. others like most of H&R's need longer studs installed. You shouldnt have to cut down anything.
Btw you dont want to use hardware store nuts, theyre probably not strong enough.
Old Oct 5, 2008 | 07:33 PM
ceph's Avatar
Default Re: Spacers and Nuts (alphalanos)
yeah, i realized i made a mistake, the 1.5 is mm, not inches, between each thread.
I got spacers from max: http://www.gtfactory.jp/cms/page.php?10. I bought some nissan lugs to go with it. The studs are attached to the spacer for the wheel.
When I put the spacer on the car (through the other four holes), the honda lugnuts are longer than the 15mm spacer, that's why I was planning to cut it so the studs are flush with the spacer.
To attach the spacer to the car, I was planning on getting these:
http://www.suburbanbolt.com/sh...20000**+++++
The other option I was thinking is just getting longer studs or use the studs on the spacer to replace the honda ones.... I am not sure what to do
justBrowsing
May 1, 2012 06:29 PM
BLK2DOOR
Apr 13, 2010 09:36 PM
x4thGenCafe
Mar 20, 2008 09:46 PM
Halo
Feb 1, 2005 04:34 PM
