B20 LSVTEC (NA STROKER KIT)
LSVTEC 2.0 motor For sale asking $2500 firm(from my old DC)
The Vtec head is off of a B16 Del Sol. The head needs new valve sleeves. I have a skunk 2 intake manifold on there w/ the hondata gasket.
The bottom end has been completely rebuilt with an eagle 2.0 stroker kit(New crankshaft and new eagle rods wiith JE pistons 12.1 compression. ITR oil pump and water pump. There is a new cometic head gasket as well. The bottom end is from an integra LS.
the engine has new precision injectors 220cc w/ new connector clips
The engine set up is OBD1 with a reflash by Katman Stage 2(you can find info on this by going to jhpusa.com)
JDM ITR tranny w/ LSD and a new stage 2 clutch(No problems on the tranny whats so ever)
There is a new distributor on board as well.
If interested send me a IM here at HT but i prefer an email: spoonchunks@sbcglobal.net
The car is located in Hillside IL Anything you want to know or if you wanna come and take a look let me know.
2000 firm, you get a the long block and ITR JDM tranny everything is in working condition. Like I said the only thing the motor needs is new valve sleeves.
The cylinder head is completely stock besides the preventative maintenance parts.
This is a great NA MOTOR!!!
PICK UP ONLY!!!
Modified by huevosrancheros at 6:04 PM 10/6/2008
Modified by huevosrancheros at 6:06 PM 10/6/2008
Modified by huevosrancheros at 5:45 PM 11/3/2008
PICK UP ONLY!!!
huevosrancheros
Jul 26, 2009 07:33 PM
drunknbass
Apr 28, 2005 02:02 PM
