Wiring Help for OBD1 loom.
Old Oct 3, 2008 | 01:42 PM
remco's Avatar
Default Wiring Help for OBD1 loom.
Hi,
Is it correct what i've got now. And what am i missing/or is wrong?
For what car is this wiringloom?
(Donno because cann't find a maching manual with the right wiring colour diagram)
Thanx in advance.
Modified by remco at 11:49 PM 10/3/2008
Old Oct 3, 2008 | 01:49 PM
esean93's Avatar
Default Re: Wiring Help for OBD1 loom. (remco)
i think it might be jdm
Old Oct 3, 2008 | 02:13 PM
obuhmyuh's Avatar
Default Re: Wiring Help for OBD1 loom. (esean93)
haha i just swapped harnesses, that's for sure a d16z6 (or similar obd1) harness. it looks just like mine, i can take pics of the one removed. and that's an evap purge solenoid plug. I'm running it with my jdm d15b though.
Old Oct 3, 2008 | 02:30 PM
Gunmetal_B20_Hatch's Avatar
Most OBD-1 B/D harnesses are the same. Only difference is the MAP sensor and IAT placement.
The one you have is weird. The IAT sensor is where a D series should be , but the MAP sensor is integrated into the harness. Maybe Z6's have the MAP on the TB too, IDK for sure. On My 92 DX hatch, I had to reuse the MAP plug from the body side harness.
EDIT: and its NOT a JDM harness...
Old Oct 3, 2008 | 02:45 PM
Spool This's Avatar
Default Re: (Gunmetal_B20_Hatch)
i think the anwser is on the harness itself! says VTi OBD1 on it.
Old Oct 3, 2008 | 10:09 PM
obuhmyuh's Avatar
Default Re: (Spool This)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spool This &raquo;</TD></TR><TR><TD CLASS="quote">i think the anwser is on the harness itself! says VTi OBD1 on it. </TD></TR></TABLE>
haha it does.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gunmetal_B20_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Maybe Z6's have the MAP on the TB too, IDK for sure. On My 92 DX hatch, I had to reuse the MAP plug from the body side harness.
EDIT: and its NOT a JDM harness... </TD></TR></TABLE>
yeah the map sensor is on the TB for z6's the TPS and the MAP are on the same "branch" on the harness.
Old Oct 4, 2008 | 12:16 AM
remco's Avatar
Default Re: (obuhmyuh)
Yeah, i know that's a OBD1 VTI but don't know the car/year.
Have checked almost every year B16/B18 haven't found any with the correct colours.
Haven't checked on the D series because it had to be a vti.(As seen on the loom)
So it's a D16Z6 loom, D-manuals here i come.
Old Oct 4, 2008 | 12:25 AM
remco's Avatar
Default Re: (remco)
Just checked the colours for the evap on the D16Z6 manual, and they are the same. (Yellow/black-Red) But all other colours are different.
Today with the multimeter a final check. Hoped it would be easier...............
Btw: Don't need the purge solenoid valve? So the connector is not used afterall?
Looked with search for the evap but a lott have removed them, so the connector stays empty.
----Cut and tape/connect to standalone purge solenoid?
thez6kid
Engine Management and Tuning
May 13, 2012 04:46 PM
B Dap
Aug 13, 2010 09:34 AM
gotboosthatch
Feb 1, 2008 09:10 AM
Mannykiller
Aug 6, 2007 03:57 PM
zlambe
May 10, 2004 05:22 PM
