b18 gsr question? Is the bolt pattern the same on a gsr as a ls header?
Old Oct 2, 2008 | 09:35 PM
80 dolla crx hf's Avatar
Default b18 gsr question? Is the bolt pattern the same on a gsr as a ls header?
I bought a cgsr but i think the 4 into 1 dc header i got is for a ls or can the headers be swaped out with no problem?
Old Oct 2, 2008 | 10:54 PM
Slain's Avatar
bolt pattern for the head is the same for all bseries. the difference is where it meets the cat. you will need a different length cat if your gsr is a 94-99(longer cat o2 bung on the inlet pipe of the cat) . if your gsr is a 00-01 (shorter cat 02 bung near the collector of the header) then the header should bolt right in.
Old Oct 3, 2008 | 05:32 AM
yep i found out that the only difference is the b16 headers should sit 1/3 in taller and they all should bolt up.
Mine is a 94 how much slack, or space will needed to be added to get the cat bolted to the header?
Old Oct 3, 2008 | 04:28 PM
Slain's Avatar
if the header is from a 94-01 ls then the cats total length i believe should be around 12 inches
xlilninjax
Oct 28, 2010 01:09 PM
blowbyu24
Nov 14, 2005 01:55 PM
Karterguy13
Jan 29, 2005 01:31 PM
Droppedatbirth!
Aug 20, 2004 09:20 PM
