B16B which hasport mounts???
the egstk or the dcstk only reason i ask is because the dcstk are for 94-01 integras but say they are compatable for 92-95 civics with a b18c1 or b18c5 swap.
and the 16b has the same block as the 18c so which mounts should i be getting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs »</TD></TR><TR><TD CLASS="quote">Hasport EGSTK are the mounts you need.
all B series swaps..</TD></TR></TABLE>
That is correct...listen to the man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Do you have a two post upper mounting bracket or a three post upper mounting bracket?</TD></TR></TABLE>
a b16b would have a 2 post engine bracket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulimports »</TD></TR><TR><TD CLASS="quote">the egstk or the dcstk only reason i ask is because the dcstk are for 94-01 integras but say they are compatable for 92-95 civics with a b18c1 or b18c5 swap.
and the 16b has the same block as the 18c so which mounts should i be getting?</TD></TR></TABLE>
yes the b16b has the same block as the b18c but it uses a 2 bolt engine bracket
the b18c uses a 3 bolt engine bracket hence the use of the DCSTK kit in 92-95 civic
all b-series swaps with a 2 bolt engine bracket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulimports »</TD></TR><TR><TD CLASS="quote">im not sure but which ones will def fit?</TD></TR></TABLE>
for a b16b into a 92-95 civic you will use the EGSTK kit
slowpokecivic
May 31, 2008 08:16 PM
1fastEK9
19
Jan 31, 2007 11:20 AM
