camshaft or aluminum flywheel?
Old Jul 27, 2002 | 11:43 AM
CiViC SiR's Avatar
Default camshaft or aluminum flywheel?
hi guys....
which one is better and more HP type R camshafts or aluminum flywheel?
Old Jul 27, 2002 | 11:46 AM
Kamin's Avatar
Default Re: camshaft or aluminum flywheel? (CiViC SiR)
a flywheel will not give you horsepower.
a flywheel makes the car faster.
i would say cams
Old Jul 27, 2002 | 12:39 PM
DelSol808's Avatar
Default Re: camshaft or aluminum flywheel? (KAMiN)
cams
Old Jul 27, 2002 | 12:42 PM
714eg's Avatar
Default Re: camshaft or aluminum flywheel? (DelSol808)
Since when did a flywheel give you HP? I would go Cams b4 a flywheel. Flywheel is not that big of a necessity.
Old Jul 27, 2002 | 12:49 PM
civEX's Avatar
Default Re: camshaft or aluminum flywheel? (714si)
A lightened flywheel won't give you horsepower but it will make you a little faster. Just think of it as making you car lighter by taking out seats, etc.
Old Jul 27, 2002 | 03:19 PM
00CIVICwB18C1's Avatar
Default Re: camshaft or aluminum flywheel? (civEX)
the lightened flywheel doesn't make your car faster by dropping 9 or so pounds off the total car weight. it does so by reducing the rotating mass inside the engine. This means less power is used to spin the flywheel, so more power is transmitted to the wheels. The same principle applies to lightweight wheels.
Old Jul 27, 2002 | 03:21 PM
allmtr's Avatar
Default Re: camshaft or aluminum flywheel? (00CIVICwB18C1)
its just reeeaaaly fun to have. watch the redline cuz youll be there in a flash
Old Jul 27, 2002 | 05:53 PM
Default Re: camshaft or aluminum flywheel? (allmtr)
Also, aluminum isn't the best material to make a flywheel out of. I'd rather have a JUN or Zex flywheel made of chromoly steel. lightweight and strong.
pentaq
Apr 29, 2003 04:36 AM
iwhichisme
Jan 9, 2002 10:33 PM
