block guard
i am builbing a ls/vtec motor with SRP dome top high compression pistons and crower stage 2 cams i am worried about the pistons slapping my valves when the vtec kicks anyone with the correct info let me kno???
<<NS-R TEGGY>>
Modified by nightshift_rolla at 7:09 PM 10/2/2008
Modified by nightshift_rolla at 7:13 PM 10/2/2008
<<NS-R TEGGY>>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightshift_rolla »</TD></TR><TR><TD CLASS="quote">i am builbing a ls/vtec motor with SRP dome top high compression pistons and crower stage 2 cams i am worried about the pistons slapping my valves when the vtec kicks anyone with the correct info let me kno???
<<NS-R TEGGY>>
Modified by nightshift_rolla at 7:13 PM 10/2/2008</TD></TR></TABLE>
I hope you are not planning on just putting the pistons in, and simply installing the cams? First of all, what is the static compression of the pistons? Are you planning on checking p2v and v2v clearances, degreeing the cams, blueprinting the bottom end ...?
<<NS-R TEGGY>>
no im not just throwing the pistons and cams in, its going to be fully built top and bottom, valves, springs, retainers, rockers, everything. i will be checking all p2v and v2v clearances, if i need to degree the cams i will but i would rather not. what is blueprinting the bottom???
blwn95civic
Oct 12, 2006 01:39 AM
jdmefhondachassis
Aug 17, 2004 10:50 AM
