Seized brakes
Would a seized rear caliper piston on my 97 Integra GS prevent me from bleeding my brakes properly and having any brake pressure, I cannot find any leaks anywhere. Thanks in advance.
you should still be able to bleed the brakes with a seized caliper. but sometimes a seized caliper piston can make the brake pedal feel soft. not soft enough that you have no brake pressure but just a mushy pedal.
you should replace seized brake componets regardless.....
