im out of idea on my da!(need HELP)
Old Oct 2, 2008 | 01:21 PM
Mr.vang's Avatar
Default im out of idea on my da!(need HELP)
ok i got some problem on my integra(DA)!
this is wants going on, my corner lights keeps blinking not the bump
lights, and my heater is not working too(its not even blowing heat and cold air) same with the defoster for the back window! need help cause winter is coming u soon! i check all the fuse aready!
Old Oct 2, 2008 | 02:46 PM
vtecallday's Avatar
Default Re: im out of idea on my da!(need HELP) (Mr.vang)
Signal lights - keeps blinking when the switch is not on?
Heater - if the climate control is all the way to the red and its still not blowing hot air. check if theirs a coolant line running to your heater core.
Defroster - check the defroster lines on the rear windshield and see if any of them is broken
Old Oct 2, 2008 | 04:42 PM
gtec8285's Avatar
Default Re: im out of idea on my da!(need HELP) (vtecallday)
soory not to thread jack but where is this heater core
Old Oct 2, 2008 | 04:48 PM
ls19integra95's Avatar
Default Re: im out of idea on my da!(need HELP) (gtec8285)
heater core is behind your dash right in the middle, if you look under the dash in the middle you will see a platic box underneath, the heater core is inside of that box...
GeorgeA
Feb 20, 2013 05:30 PM
toolow69
12
Nov 3, 2008 09:39 PM
blakacintegra
Dec 6, 2006 06:55 AM
ED6JDM
Oct 15, 2006 06:45 PM
futurefastguy
Sep 8, 2006 06:31 AM
