1990 accord lx smokin prob
I have an 90 accord lx with about 244,000 miles on it and it has been runnin quite well 4 some years now... but over the past week or two i have started to notice my oil to go missin... its not leakin out anywhere... there is also a white blueish smoke that constantly comes out of the tail pipe.... when u drive the car it comes out even worse... could some one give me some kind of idea about what this problem is
thanks
thanks
Does the car lose any coolant? Or just oil? The fact that you say blueish smoke leads me to believe that you have worn piston rings ... hence needing an engine rebuild or replacement. If you are losing coolant, then the earlier reply about a head gasket problem is a possibility.
IMHO, with a car that old and probably unknown maintenance history, I'd be looking for a lower mileage used engine to install rather spend the $$ to pull that one apart.
Good luck w/ your project.
First Honda 1976
Apr 23, 2004 03:22 PM
