1990 Honda Civic DX 4 Door Automatic. d15b2 to a ZC swap.
THis is me and my friends first time swapping an engine, and we decied to do this honda 1990 civic with a d15b2 we have been sitting on for about 3 months.
i bought a ZC engine from attarco for 450 dollars.
we are in the process of pulling out the engine right now.
we are hoping we do not have any problems with the swap, but i was expecting the ZC to have a black valve cover and this one is silver, but it looks like it ha been painted.
either way what parts am i still going to need before we drop the ZC in? any help on a d15b2 to a ZC engine swap or write up is greatly appricated... like i sad.. this is our first time.
thanks in advance.
and here is pics of the project so far.
the car
thanks in advance.
the car
thats a sohc zc. its the kinda the same motor as the d16a6 motor that came in a usdm crx si. the b2 have a dual point fuel injection, you need to convert your harness to a multipoint, or just get a si harness off a 88-91 civic/crx or an ex harness off a 88-91 civic sedan.
after that you need the right ecu, i would normally say pm6 ecu, but who knows what you could find better.
that motor is pretty much just plug and play after the harness conversion.
you need to make sure that your using a multipoint fuel injection manifold.
plus if you want to be 5/4 speed an 88-91 civic/crx si tranny is good. make sure you grab the pedal assembly, shifter and shift linkage. [good thing about cable transmission is you dont have to worry about getting a master cylinder for the clutch. unless you want a hydro clutch]
google sohc zc motor swap.
youll find how to's.
hey thanks for the info,
what kinda car can i get a multi point fuel injection manifold off of?? what about injector resistor? do i need this?
also how do i tell what kinda ECU i am looking at?
also as for converting to a multipoint,
i think i wanna just get the harness of of a si or a sedan EX,
considering my car is a sedan should i get it off of an EX?
or should i just get the Si? does it make a diffirence? what is the best harness?
your going to have to make your dpfi harness into a mpfi harness. not too hard. i dont know what ecu the soch zc uses but i would get a pm6 si ecu,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avlove26 »</TD></TR><TR><TD CLASS="quote">also as for converting to a multipoint,
harness wise, either/or would be fine. thats if you can find one thats not all hacked up.
ecu wise get it off a crx si, PM6.
intake manifold wise, get it off a d16a6.
how did you pull the motor out without taking off the tranny? haha.
we are letting the JB weld cure, then we will finsih up tomorrow, we got everything needed, and everything is ready to get completed tomorrow
one problem we are having is with the power steering bracket,
anyone kno of or had this problem before?
get a manual rack off a crx/civic si. you dont need power steering.
or you should have taken the tranny off with the motor.
and bolted it back on before dropping the motor in there.
ok i got a couple questions if any one can help
when it comes to getting a intake manifold off of a CRX or a SI,
how do i know which one to get for sure,
this wrecking yard has a CRX MPFI intake, and it has a bunch of air lines, that go to a box,
is that what i want?
do i need to take the whole box also? can some one help clarify this for me??
_____________
also the power sterring bracet does not fit, anyone else find a way around this??
_______________
any help is greatly appricated.
thanks
_____________
_______________
thanks
ok i got a questions
what does the mpfi manifold have to be off of
there is a 4 door teg, that has a mpfi manifold, but it is to a b16 i belive
some one please help, so that i can buy the manifold allready
there is a 88 civix HF, with a PM8 ecu, and a manifold that should work... shoulsd i grab that one....???
ok i got everything done but i got a problem,
when i go to turn over the car with the key,
the ignition control modudule clicks non stop,
and it does not do nothing,
i took a video and posted it below, so you can check it out yourself, it is dark, but you can see lights when i try to start the car.
has any one experienced this or know what it might be? what i can check what i did wrong...??
any help please is greatly appricated.
thanks!
click for video ---->
http://s45.photobucket.com/alb...g.flv
Modified by avlove26 at 10:08 PM 10/8/2008
thanks!
