Help Installing Flywheel dust cover!
Old Oct 2, 2008 | 10:55 AM
JasonST's Avatar
Default Help Installing Flywheel dust cover!
I'm in the process of rebuilding the d15b2 in my 4 door right now and for whatever reason having trouble with the flywheel cover. I'm not exactly sure how I took it off it was a couple of weeks ago. The problem is when I'm trying to put it back on it won't fit unless I take the oil pan out, then when I put it in I can't get the oil pan back on. I'm so confused they both WONT fit together. What am I doing wrong. Thanks for any help.
Old Oct 2, 2008 | 11:03 AM
2slow4stock's Avatar
Slide the shield from the firewall side of the trans to the front, it will wiggle right in. Also would help if you had it at an angle to slide the flywheel shield on.
Old Oct 2, 2008 | 11:05 AM
JasonST's Avatar
Default Re: (2slow4stock)
Does the oil pan go on first or the dust cover?
Old Oct 2, 2008 | 11:16 AM
90sedan's Avatar
Default Re: (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Does the oil pan go on first or the dust cover?</TD></TR></TABLE>
Yes, all you need to remove is two of the 10mm bolts on the Oil pan, there is no need to actually remove the entire pan.
Old Oct 2, 2008 | 11:17 AM
JasonST's Avatar
Default Re: (90sedan)
Ok, thanks guys for clearing that up! I'll get right on it as soon as it stops raining. Thanks for the help.
zexifiedlude
Mar 14, 2006 07:05 AM
shbrown
Jan 28, 2006 03:46 PM
AF-b16a1
Aug 2, 2004 09:53 PM
92civeg
Jan 7, 2004 12:35 PM
