OEM pistong ring gap spec the same for standard and oversize?
I have an acura service manual and im trying to gap my piston rings.
I have .25 over usdm ITR pistons and i dont know if the standard pistong ring gap in the manual is the same for oversized pistons.
Can anyone clarify this for me?
What ring package are you using? I use the hastings ring pack which is the same for 81 to 82 mm pistons. I never had a problem with gap being 1 thou bigger than standard size. The main thing is makeing sure the rings are clocked correctly and the up side is actually up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">What ring package are you using? I use the hastings ring pack which is the same for 81 to 82 mm pistons. I never had a problem with gap being 1 thou bigger than standard size. The main thing is makeing sure the rings are clocked correctly and the up side is actually up.</TD></TR></TABLE>
im using OEM oversize PR3 rings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boredracer408 »</TD></TR><TR><TD CLASS="quote">
im using OEM oversize PR3 rings.</TD></TR></TABLE>
Then you should not have a problem.
