Crazy idle with video
Old Oct 2, 2008 | 09:32 AM
menthos's Avatar
Default Crazy idle with video
my car has a bit crazy cold idle:
http://www.youtube.com/watch?v=ajlye5OR77w
the engine is a b16a2 from an civic EK
at :09 and :15 i press the throttle...
anyone knows what could be wrong??
Old Oct 2, 2008 | 09:39 AM
h-duced's Avatar
Default Re: Crazy idle with video (menthos)
seemed pretty normal to me. Its cold of course its gonna idle different. How is it when it warms up?
Old Oct 2, 2008 | 10:34 AM
menthos's Avatar
Default Re: Crazy idle with video (h-duced)
when it is warm the idle is fine...
well i don't think it's normal that it should drop that much when i realease the throttle... it almost kills the engine... goes down to 200-300rpm...
Old Oct 2, 2008 | 12:00 PM
menthos's Avatar
bump
Old Oct 2, 2008 | 01:18 PM
tx_ej8_49's Avatar
My 96 sohc civic, 97 2.3 cl and both my mazdas did that it i just tapped the throttle on cold days and at start up.....
Old Oct 2, 2008 | 02:22 PM
menthos's Avatar
Default Re: (tx_ej8_49)
well it can run without pressing the throttle...
but im sure the is not how it should be since the idle falls so low when i release the throttle + the cold idle rices form about 400 to 1500rpm... 1500 is a bit high..
Old Oct 2, 2008 | 02:32 PM
riceburnerryan's Avatar
looked pretty normal to me as well...
Old Oct 2, 2008 | 02:48 PM
hard_boiled_EG's Avatar
Default Re: (riceburnerryan)
check your timing if your worried...you might just have to advance your dizzy just a little bit.
Old Oct 2, 2008 | 02:53 PM
menthos's Avatar
why doesn't my d16z6 do the same then?
it can't be normal that the engine almost dies when i release the throttle, i can hear the engine makes a cough like it is dieing...
it's hard to hear on the video but it is right about :17
Old Oct 2, 2008 | 07:25 PM
geebs's Avatar
Default Re: (menthos)
Maybe the IACV is sluggish? Maybe its just dirty? Try cleaning it out, and see if that makes any difference.
Old Oct 2, 2008 | 09:40 PM
menthos's Avatar
Default Re: (geebs)
i have tried that... didn't make any difference...
Old Oct 3, 2008 | 02:59 AM
menthos's Avatar
Default Re: (hard_boiled_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hard_boiled_EG &raquo;</TD></TR><TR><TD CLASS="quote">check your timing if your worried...you might just have to advance your dizzy just a little bit.</TD></TR></TABLE>
well the car hasn't been out running for half af year i think (it has been turned on several times but not for long), but before that im pretty sure that it didn't have a crazy idle like now
Old Oct 3, 2008 | 03:56 AM
chickenwing's Avatar
i got the same issue when my d series is warm.
once you release the throttle it drop to 300 rpms and stutters a bit before going back up to idle.
sometimes when coming to a stop i press in the clutch the rpms drop to 300 and car stalls.
just idling by itself it is okay and does not fluctuate up to 1500 and down to 800.
Iloveyourhonda92
Apr 11, 2015 07:46 PM
mad21kid
Feb 18, 2008 12:52 PM
Mr.Death
Aug 18, 2006 10:08 AM
'99luder
Apr 4, 2004 03:15 AM
B18CRacer
Jan 29, 2002 09:22 PM
