Whats the best Over-All SHort Shifter for 98 Honda Civic Coupe?
I am looking to buy a short Shifter for my 98 Honda Civic Coupe (Ex). I baught a Reactive (Rice) short shifter and it didn't even fit. I was wondering which one I should buy. I really have no spending limit. Also if you know where I could get it online please also include a URL Link. Thanks again!
stock.
why shift faster than the rpm's fall.
dont waste the money
and it could put alot more strain on the tranny.
stock.
http://www.landspeedracing.com 111 bux shipped
Whatever short shifter you get, pick up a steel alloy model, like C's, Skunk2, and B&M.
Where and how much did you pick up your Skunk2 shifter for?
i got the skunk2, love it but one question is the skunk2 sit the same height as the stock shifter? cause mine does its not really low like the others short shifters.. (b&m, dc)
You can order a C's Short Shifter at my work...
SP Engineering
(626) 333-5398
www.sp-power.com/
Ask for Daryl. We do not have any in stock right now, you will have to place an order.
[Modified by SloEG, 1:27 AM 7/30/2002]
SP Engineering
(626) 333-5398
www.sp-power.com/
Nothing special, it has a titanium color. It's made of alloy steel, not aluminum, so no worries it will snap. No one has ever had any complaints on the way it fits or shifting problems....but as long as you find another alloy steel shifter and does the same job, your fine. Unless you want to pay for the look and know you will have no worries about grinding gears, etc, etc.. I reallyneed to open the box up when we get some and take a look, maybe some pictures.
u can actually make your own short shifter with a welder and a skil saw (i think thats the name)
If you cut the top of a shifter off, you put in more "work", move your arm less, but dont come in/out of gears any faster.
When you lengthen the rod below the ball, and shorten the rod above the ball, you put in more "work" move your arm less, and come in/out gears faster.
And the only way it puts more strain on the tranny is if you bang gears, which most people do with a stock shifter, but because they have more leverage, if feels "softer".
To feel it for yourself. Take a 3/8 in drive ratchet and tighten down a bolt. Then take a 1/4 in drive ratchet and try to loosen it. Then do the reverse.
stock.
maybe if u think about how much faster it is to hit the next gear????
look dude
no matter how fast you shift
the engine STILL HAS TO SPIN DOWN to match the gear.
if you are shifting faster than the drop you WILL do damage over time.
look dude
But you dont have to say it. We already know dude dont have one, and probably never will.
stock.
Stick with stock -- trust me on this one.
