D16z6 motor/ D16Y8 intake MAp sensor question
Old Oct 1, 2008 | 07:11 PM
tico's Avatar
Default D16z6 motor/ D16Y8 intake MAp sensor question
whats up HT. i picked up a Z6 from my homie and it cam with a Y8 intake. my question is the map sensor on the throttle body. how will this work when i have the map sensor on my firewall that use the vacum lines? do i use both or just one of them
Old Oct 1, 2008 | 07:46 PM
Red_ED8's Avatar
Default Re: D16z6 motor/ D16Y8 intake MAp sensor question (tico)
Check this link out, it is a dyi on the Y8 mani swap. I think you just extend the map sensor wire and use the one on the tb (someone correct me if I'm wrong).
http://www.geocities.com/joeyp....html
Old Oct 1, 2008 | 07:52 PM
D16SiHatch's Avatar
Default Re: D16z6 motor/ D16Y8 intake MAp sensor question (Red_ED8)
you actually dont necessarily even have to extend the wires. and yea thats right, just unplug the harness from the map on the firewall, and snap it into place on the tb mounted y8 map.
Old Oct 1, 2008 | 07:55 PM
SovXietday's Avatar
Default Re: D16z6 motor/ D16Y8 intake MAp sensor question (D16SiHatch)
You can do this two ways, depending on what you want to do.
1) You can keep your firewall mounted map sensor and just plug the spot on the Y8 TB. Run vacuum lines like normal.
2) You can use the Y8 style one, but you will probably want to extend the wires because it is a very tight fit without doing so.
Old Oct 1, 2008 | 09:08 PM
89s1's Avatar
Default Re: D16z6 motor/ D16Y8 intake MAp sensor question (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">You can do this two ways, depending on what you want to do.
2) You can use the Y8 style one, but you will probably want to extend the wires because it is a very tight fit without doing so. </TD></TR></TABLE>
I did the firewall style on my sirII. It was easier than extending wires.
Old Oct 1, 2008 | 09:18 PM
D16SiHatch's Avatar
Default Re: D16z6 motor/ D16Y8 intake MAp sensor question (89s1)
yea extending the wires would probably be a good idea no doubt but i was lazy. i just left the stock map on the firewall also, so now i have a backup
Old Oct 3, 2008 | 10:01 AM
nfereorhatch's Avatar
You actually don't have to "extend" the wires. All you have to do is strip off the loom on the map sensor wires and at the base of where it comes out cut back the tape to free enough slack to run to the tb mounted map sensor. Put the loom back on and you are done. I did mine like that because i deleted everything off the firewall though, just looks cleaner to me.
Modified by nfereorhatch at 12:13 AM 10/4/2008
Old Oct 3, 2008 | 11:39 AM
tico's Avatar
Default Re: D16z6 motor/ D16Y8 intake MAp sensor question (nfereorhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfereorhatch &raquo;</TD></TR><TR><TD CLASS="quote">You actually don't have to "extend" the wires. All you have to do is strip off the loom on the map sensor wire and at the base of where it comes out cut back the tape to free enough slack to run to the tb mounted map sensor. Put the loom back on and you are done. I did mine like that because i deleted everything off the firewall though, just looks cleaner to me. </TD></TR></TABLE>
i was hoping to clear up my firewall a bit so this really helps me out, thnx HT
175Shot4Door
Mar 2, 2007 08:26 AM
Mr.Death
Jul 5, 2005 07:09 PM
Ricey McRicerton
11
Oct 19, 2003 09:35 PM
Kusai.Nihonjin.Desu
Aug 18, 2003 02:25 PM
CimorelliCRX
May 14, 2003 09:38 AM
