d15b2 mini me swap the right way!
Well i have a 1988 civic lx. comes stock with a d15b2. 92hp. =P
if someone couple please list every single part i need for a mini me swap
the right way. it would be greatly appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaBread »</TD></TR><TR><TD CLASS="quote">no i havent done tha mpfi swap yet. its still dpfi. but i think thats the first thing imma do then. what would i need to go from dpfi to mpfi?</TD></TR></TABLE>
You are about 5 hours worth of searching away from asking that question right about now.
You're lucky you got what you did.
I was about ready to just reply "search" to your original post.
Don't poke a sleeping bear.
i figured it out.
these are the parts i need.
88-91 Civic/CRX Si Complete Intake manifold w/Throttlebody and Injectors
88-91 Civic/CRX Si Complete Distributor(TD-02U)
88-91 Civic/CRX Si Complete Engine Wiring Harness
88-91 Civic/CRX Si Injector Resistor Box
88-91 Civic/CRX Si PM6 ECU
88-91 Civic/CRX Si Throttle Cable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaBread »</TD></TR><TR><TD CLASS="quote">i figured it out.
88-91 Civic/CRX Si Throttle Cable</TD></TR></TABLE>
Killer! job well done.
Thanks for posting that in your reply.
this thread is now likely to help someone else searching in the future.
Also. there is a little bit more horespower to be found if you substiute the si intake manifold for a vtec version off the d16z6 or d16y8. Just figured you would like to know.
OH! and you dont absolutely NEED the si throttle cable. you can use yours if you just loop it around the drivers side mount before attaching it.
You unlock a bit of info on your own and i'll help out with a bit of my own from my own memory archives/personal experience.
You are going to want to use your existing wiring harness and add the necessary extra wires for the injectors and distributor. Using the Si harness will only give you headaches. The only thing the Si harness is good for is the extra plugs you'll need for the distributor and injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">You are going to want to use your existing wiring harness and add the necessary extra wires for the injectors and distributor. Using the Si harness will only give you headaches. The only thing the Si harness is good for is the extra plugs you'll need for the distributor and injectors.</TD></TR></TABLE>
oh, **** i didn't even notice he had the harness written down there.
Redline is correct. You will want to add the necessary wires, it sounds like more work but really is less.
oh alright then.
well to make tha whole thing easier.
i can juss buy tha dpfi to mpfi conversion harness.
something like this.
http://cgi.ebay.com/ebaymotors....m245
still havent been able to collect all the parts.
ive had to spend all my money on fixing the damn car.
an oil leak between the engine and tranny.
and my car has a very high idle which i cant seem to solve.
3,000 rpm!!
soon enough though ill have everything underway.
3,000 rpm!!
sup man..im actually not going to get that engine cause of the hydro and cable clutch situation..im picking up a 91 CRX Si engine for 200...which is the D16A6....iTS CABLE AND OBD 0...
Awesome build, this thread has helped me a lot. I'm goin to do this in my car. It really sux cuz about 3 months ago I put in a new d15 into my ef, now that I know about hondas and the different engines I was kinda mad... But now I know about THE MINI ME SWAP.
trust me on this. dont waste ur time with a mini me and mpfi swap. u really end up wasting lots of time and lots of money. and in the end, you dont get wut you really want.
save up for a b-series engine, and do a complete swap. its much much better. its wut im doing with my stock b15b2.
then when u swap it out. you can get 450-600+ $ for ur d15, im sure someone wants it.
i do have a z6 head, d16 intake mani with all the sensors. fuel rail, FPR, injectors, TB, and injector res box. i also have a VTEC solenoid with the plug. i live in SD, and i see ur in cali too. I would be glad to sell you the stuff i have, as i wont need it anymore. i could even drive it to you and help you with as much of it as possible.
i got a lot of ef **** sitting in my room. if u wanna work something out. pm me yo. but if u ever need a set of hands. i could always find some time.
