squeeky steering when stopped
Old Oct 1, 2008 | 06:09 PM
hondazccivic's Avatar
Default squeeky steering when stopped
Hey, other then needing an alignment which I know I do, what would cause the car to squeek when turn the steering wheel and not moving, or moving very slow? Steering is not affecting, other then it pulling to the left, due to me needing an alignment.
Old Oct 1, 2008 | 06:22 PM
speedracer9k's Avatar
need more information...where is it squeeking from? steering wheel, suspension, tires? More info please
Old Oct 1, 2008 | 06:48 PM
SDHonda153's Avatar
Default Re: (speedracer9k)
Sounds like it could be the ball joint
Old Oct 3, 2008 | 03:47 AM
Default Re: (SDHonda153)
Ball joint was my first guess. It's coming from the left, hard to hear from exactly where, but don't think it's a steering issue, as my steering is still ok. How hard is it to change out the lower ball joint yourself? What tools will I need? Looks like they are pressed in, never done one before? Let me know guys.
Old Oct 4, 2008 | 06:36 PM
Default Re: (hondazccivic)
any input guys? Let me know, thanks.
Old Oct 4, 2008 | 06:44 PM
Fook_me_honda's Avatar
Depends on which ball joint your replacing. but the one connecting to the front LCA will need to be pressed out. ive heard you can hammer it out but it has never worked for me. as for the steering rack ball joint, when you buy the piece just buy the whole tie rod end. itll make life easier.
Old Oct 4, 2008 | 07:11 PM
geebs's Avatar
Default Re: (Fook_me_honda)
For the lower ball joints.. there is a snap ring on the top part of it.. Remove the snap ring.. Find a socket big enough that'll fit the ball joint.. I think i used a 19mm impact from snapon. Hammer it out.. should come out with a few good whacks.
The upper ball joints I've never replaced.. I'd imagine they're somewhat the same.
Old Oct 4, 2008 | 07:16 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs &raquo;</TD></TR><TR><TD CLASS="quote">The upper ball joints I've never replaced.. I'd imagine they're somewhat the same.</TD></TR></TABLE>
The uppers are not, they are part of the upper control arm. Order upper control arms and they will come with upper ball joints.
Old Oct 4, 2008 | 07:34 PM
Default Re: (mcvtec)
im pretty sure you can remove the uppers by themselves. ive seen people do them to use upper balljoint camber kits.
Old Oct 4, 2008 | 07:40 PM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fook_me_honda &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure you can remove the uppers by themselves. ive seen people do them to use upper balljoint camber kits.</TD></TR></TABLE>
Touche`.
But not OE replacement.
Old Oct 5, 2008 | 08:20 AM
when hitting the lower ball joint that connects to the front LCA, do i hit it towards the ground or upwards? Not sure how these come out, never done one before, let me know thanks.
Old Oct 5, 2008 | 08:31 AM
sky7's Avatar
if the snap ring is on top, then it keeps the joint from falling down so take off the ring and hit it down. if te ring is on the bottom, then opposite is true.
Old Oct 6, 2008 | 09:00 PM
geebs's Avatar
Default Re: (sky7)
The snap ring should be on the top of the ball joint.. towards the axle..
You need to remove the snap ring, and hammer it up towards the axle.
Old Oct 11, 2008 | 02:36 PM
Default Re: (geebs)
Do inner tie rods squeek when they are bad?
Old Oct 11, 2008 | 02:42 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs &raquo;</TD></TR><TR><TD CLASS="quote">The snap ring should be on the top of the ball joint.. towards the axle..
Nope. The snap ring (if it has one) is on the bottom, LCA side.
Old Oct 11, 2008 | 04:28 PM
ok cool, me and a friend were checking out the squeeking and it sounds like it's coming from the inner tierod, any input guys?
Old Oct 11, 2008 | 04:55 PM
Pothole987's Avatar
is there any movement when the wheel is on, the car jacked up side to side?
a squeaking while turning the wheel could be something in the rack..
and are you sure its not a belt squeal?
Old Oct 12, 2008 | 09:30 AM
Default Re: (Pothole987)
definetely not a belt squeel. I do need an alignment, hopefully get one today after I do my balljoint. Really sounds like it's coming from the rightside inner tierod, but i'm not sure. Any ideas?
Old Oct 14, 2008 | 02:21 AM
possibility of any asuspension parts goin bad?
Old Oct 16, 2008 | 08:20 PM
ok so I adjusted the alignment, which is pretty much dead on, both sides outter tie rods changed, left lower and upper ball joint, aswel as upper left control arm. What could cause the squeaking in the steering when stopped or at very slow speeds? no play in steering wheel either, let me know guys, gonna try and do it this weekend, if I find out what it is.
buzkilr
May 26, 2011 12:21 PM
Annihilator
Feb 9, 2011 12:03 AM
d16efsedan
Jul 19, 2008 11:12 AM
Black R
Jul 29, 2004 02:54 PM
jabroni95gsr
Feb 13, 2003 04:12 AM
