How to tell dohc zc or sohc zc
someone is selling a spun bearing zc locally. I plan on building this for boost, i have a dohc zc. Is there any way to tell between the sohc zc and dohc zc? are they the same? Please let me know wat to look for. thanks.
**Oh yea is there any aftermarket forged/ low compression pistons for a dohc zc? ive checked endyne rollerwaves but they were a lil pricey. Ive heard vitaras will bring the compression wayyy too low. thanks
SOHC (1 cam) ZC:
120 hp 100 trq (9.1 comp)
http://www.hmotorsonline.com/s...30020
DOHC (2 cams) ZC:
129 hp 106 trq (9.6 comp)
http://www.hmotorsonline.com/s...30022
DOHC (2 cams) ZC:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therotaryrocket »</TD></TR><TR><TD CLASS="quote">lets just assume he's speaking of comparing the engine blocks without the heads.</TD></TR></TABLE>
Yeah, lets just go with that.
If you're looking at the pistons just look for a PM7 stamp on them thats the dohc pistons.
Also for a decent compression PM6 (d16a6) pistons with a thinner than stock headgasket or a little bit of milling off the top would result in about a 8.5:1 compression ratio.
Edit: Almost forgot but when I bought a ZC with a spun bearing I had to buy all new connecting rods and a new crankshaft because of the damage and out of roundness. Don't forget that 88 and a few 89 ZC's have a 22mm snout on the crankshaft meaning that sourcing a new crank counld be quite time consuming.
yea im not that stupid i know the diff between sohc n dohc. maybe i shouldve been more clearer lol. but yea the guy is selling a complete zc block. what would the sohc zc pistons say?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic90zc »</TD></TR><TR><TD CLASS="quote">i dont know if they ever came with a halfshaft but my sohc zc block has the three mounting holes for one on the back</TD></TR></TABLE>
duly noted.
I have one of each in my shed, but they are SO buried i couldn't go check
duly noted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 »</TD></TR><TR><TD CLASS="quote">
duly noted.
I have one of each in my shed, but they are SO buried i couldn't go check</TD></TR></TABLE>
THis is my SOHC zc..
duly noted.
4door93civic
Feb 1, 2008 08:46 PM
