REAR DISC BRAKE CONVERSION
you need, the trailing arms, parking brake cables, and rubber flex hoses. If you are also upgrading the front brakes to integra units (this is actually what really gives you better braking, then you will need a 4040 prop valve from a non abs integra and either an MC and brake booster from a non abs integra, or a '91 EX master cylinder.
yes you can. What I did was remove the actuator that is the part that engages on the spindle, just for peace of mind. I didn't want to hear a clanky sound every time it hit the ring gear going down the road.
2DoorBandit
12
Jul 7, 2006 12:14 PM
