REV Limit, NA build jdm b18c type-R
How high can i safely rev up the engine with my setup? I'm also adding a cel light indicator to light up when shifting in recomended, what would be a recommended shifting point in the rpm band?
Thanks in advanced.
engine setup, 2-layer head gasket , jdm s80 lsd tranny, 310cc injectors, skunk2 high comp valves, skunk2 pro valve springs, skunk2 vtec ti retainers, skunk2 pro2+ v-tec cams, skunk2 pro cam gears, skunk2 pro ntake manifold, and bbk 70mm TB.
Thanks in advanced.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGgoJDM »</TD></TR><TR><TD CLASS="quote">How high can i safely rev up the engine with my setup? I'm also adding a cel light indicator to light up when shifting in recomended, what would be a recommended shifting point in the rpm band?
Thanks in advanced.
engine setup, 2-layer head gasket , jdm s80 lsd tranny, 310cc injectors, skunk2 high comp valves, skunk2 pro valve springs, skunk2 vtec ti retainers, skunk2 pro2+ v-tec cams, skunk2 pro cam gears, skunk2 pro ntake manifold, and bbk 70mm TB. </TD></TR></TABLE>
get it built and tuned then look at the dyno sheet to see where you stop making power and dont rev past that.... not beneficial to rev past your peak power especially for a street engine
Thanks in advanced.
What he said.... With a similar set up I made power to 11,500. Rev to where you make power then stop.
Modified by JusAnother1 at 8:26 AM 10/2/2008
thanks everyone for your input
you have a point metlmadman. I sure will tune in the future.
thanks fat chick mag for the rev limit info and IOhatch for the 10% above power peak rev limit mark info.
Modified by EGgoJDM at 2:31 PM 10/1/2008
you have a point metlmadman. I sure will tune in the future.thanks fat chick mag for the rev limit info and IOhatch for the 10% above power peak rev limit mark info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Sounds good to me. 12,500 </TD></TR></TABLE>
WTF? it aint no wankel lmao!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet »</TD></TR><TR><TD CLASS="quote">ITR is 9,000 rpm safe, but I don't rev mine past 8800 RPM.. pointless stops making power after that.</TD></TR></TABLE>
it is not pointless to rev past where it makes max power.
you want to shift at the rpm where it is no longer beneficial to be in that gear.
very true ide say just past where ur peak power is at. just ask ur tuner wen tuning hell set up with a good point and let u kno. but as for a similiar setup making power to 12500 ide say maybe in ur dreams guy...
i just spit out my monster all over my keyboard lmfaooooooooo
God i love Don.
Your rev limit isn't just where you stop making power.. I wish people would STFU who don't know wtf they're talking about..
God i love Don.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMo Tuning »</TD></TR><TR><TD CLASS="quote">
SHHHH quit given hints
This subject has been research about 20 different times.. Search Rev limit or Shift points or Redline and see what you get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 »</TD></TR><TR><TD CLASS="quote">Rev it until it shuts itself off.</TD></TR></TABLE>
best advice as of yet because I see a thiner HG for higher compression, bigger fuel injectors, new cams/camgears, and a bunch of other head mods to support more power, but yet no ecu or even VAFC to regulate the a/f ratio. If you run all those mods with a stock ecu, I don't know a lot about B series, but I'd say your motor won't last long if you can even get it to run at all.
would it be wise for this guy to spin past stock rev-limit considering his bottom could be stock? that's something i was always wondering about (the valvetrain can handle it, but can the OEM bottom end bits?)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mashimaro »</TD></TR><TR><TD CLASS="quote">would it be wise for this guy to spin past stock rev-limit considering his bottom could be stock? that's something i was always wondering about (the valvetrain can handle it, but can the OEM bottom end bits?)...</TD></TR></TABLE>
Stock itr block is safe to rev high..
Yeah, that's too much work. So I'm just proposing that DonF had the correct answer.
89hatcher
Aug 2, 2007 02:51 PM
=ITRpoweredEK9=
Sep 15, 2005 04:50 AM
nomotor
Jul 22, 2004 06:23 AM
