O2 sensor CEL
Old Oct 1, 2008 | 11:59 AM
ThA IntegrA HI's Avatar
Default O2 sensor CEL
Okay the story is I just got this car, it's a 98 Civic with GSR running a chipped p28, the CEL always comes on after about 10-15 minutes of driving. I checked and it flashes really fast once for code one, which is O2 sensor 1. My question is why does it keep coming on? I installed an O2 sensor in the header last weekend because it previously didn't have one and I was getting bad gas mileage. Is there a way to reset it? And am I supposed to have two O2 sensors, the CEL is always for number one when I check it no matter which plug the O2 sensor is plugged into in the bay.
Old Oct 1, 2008 | 12:15 PM
HitF8's Avatar
Default Re: O2 sensor CEL (ThA IntegrA HI)
are you running a OBD1 harness or OBD2 harness?
Old Oct 2, 2008 | 01:15 AM
Old Oct 2, 2008 | 01:40 AM
b16_sol_707's Avatar
are you using a obd2a to obd1 jumper harness?
Old Oct 2, 2008 | 07:27 AM
HitF8's Avatar
Default Re: (b16_sol_707)
your supposed to have 2 O2 sensors with a OBD2 harness. i've heard of a peice you can buy that plugs into the conector to trick the ECU but i forget what its called. try searching it. good luck
Old Oct 2, 2008 | 09:58 AM
00b20vtecoupe's Avatar
Default Re: (HitF8)
if ur using a chipped p28 then ur using a jumper harness which converts u to obd1 which means u dont need ur 2nd o2 which really doesnt help u i guess but i would try resetting ur computer and then seeing if it comes back on.
Old Oct 2, 2008 | 10:05 AM
Burnt Toast's Avatar
Did you install a NEW o2 sensor or a used one? Also was it oem or an aftermarket brand? I've read that with the Bosch, sometimes you get a bad one that stops working right away.
Old Oct 2, 2008 | 10:47 AM
its a used one that came with the car
its was always plugged in but it was laying in the bay not in the exhaust system
Old Oct 2, 2008 | 04:14 PM
Default Re: (ThA IntegrA HI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThA IntegrA HI &raquo;</TD></TR><TR><TD CLASS="quote">its a used one that came with the car
its was always plugged in but it was laying in the bay not in the exhaust system</TD></TR></TABLE>
Maybe its bad, get a new one.
Old Oct 2, 2008 | 06:33 PM
+1, it's probably a bad sensor.
Old Oct 12, 2008 | 02:05 PM
k it seems to have gone away by it self. =]
got 60+ more miles to the tank too.
Ef8crxsi4u2nv
Apr 23, 2011 08:23 AM
HarosGSRek
Jun 24, 2009 05:08 PM
Jap_Spec_Imports
Aug 6, 2008 09:57 AM
4dek
10
May 28, 2008 02:49 PM
mugenhatchie
Apr 6, 2005 09:35 PM
