Indiglo gauge install help
Old Jul 27, 2002 | 08:16 AM
y2kintegra's Avatar
Default Indiglo gauge install help
Can someone please help me?
I have installed reverse indiglo gauges into my 2000 Integra. I used a fuse splitter to power the gauges off the instrument panel fuse. The gauges work fine when the can isn't running, but once the car is started, the gauges shut off.
If you have any ideas, please let me know.
Old Jul 27, 2002 | 09:49 AM
aCuRaLsTuRbO's Avatar
Default Re: Indiglo gauge install help (y2kintegra)
Here is what you do, listen very, very carefully. You take the gauges and the original box that they came in... Put them back in and then you set them on the floor...put gasoline all over the box. and throw a match on it and step away..Then, you read all the posts on hondatech, and visit JDMHONDAPARTS.com. Throw away your altezza tail lights. and i think there still might be hope for you..GOOD LUCK!
Old Jul 27, 2002 | 10:40 AM
maxxdout's Avatar
well, other then that, it sounds to me like you have something wired to a reverse ground. Or other words, backwards. The + that i think you are using recieves current when the car is off, or the assessory is not activated. Try swapping the wires around and see what you get.
If that doesnt work forget the splitter and just tap right into the dimmer switch wires. Nothin to it.
Hope you like um, had some similar the old style a few years back, wasnt too happy, but enjoy
Old Jul 27, 2002 | 10:46 AM
LBC vee's Avatar
Default Re: Indiglo gauge install help (maxxdout)
splice it to the dimmer switch wire..thas what i had on my car..it works fine. good luck
Old Jul 29, 2002 | 01:05 AM
Default Re: Indiglo gauge install help (LBC vee)
So....did u burn them? hehe
ppiart
Oct 22, 2013 06:30 AM
syne
Nov 10, 2008 11:16 PM
civiceg500
10
Dec 29, 2004 03:14 PM
sonicblueteg2k
May 1, 2003 03:56 PM
y2kintegra
Jul 27, 2002 08:01 AM
