FOG LIGHTS!!! there killling me!!!
Old Oct 1, 2008 | 07:15 AM
EK_kidd's Avatar
Default FOG LIGHTS!!! there killling me!!!
ok so check this out.. i blew out my last set of fog, i guees cuz i had them wire to my lights. anyways im trying to do them the right way now... i need help bad plzz if you know help me out.. i tried the diagram but still no luck
well i know...
#1 connects to the fog light harness
#2 ???? i have no clue
#3 to the switch
#4 ??? have no clue
#5 ??? i have no clue im guessing its another ground
i heard one of them go's onto the fuse box but which plug? and where in the fuse???
anyone had detailed pic?
help me out plzz
Old Oct 1, 2008 | 07:25 AM
fryguy190's Avatar
Default Re: FOG LIGHTS!!! there killling me!!! (EK_kidd)
yea ur number 4 is ither a positive or its gona plug into you fuse box.
here is a pic. but its should go to the second port not the first. bc the switch should turn on and off with your parking lights.
hope this helps.
but fyi your harness looks like its been cut and rewired bc its really short.
Old Oct 1, 2008 | 07:44 AM
EK_kidd's Avatar
Default Re: FOG LIGHTS!!! there killling me!!! (fryguy190)
yeah i did it... wiring and rewiring again smh..
WHAT ABOUT #2? where does that go?
Old Oct 1, 2008 | 10:37 AM
IB4TL FTW's Avatar
#2 goes to your fuse box, #4 is your positive, connects to positive on the other side of your firewall. just pull the rubber sleeve back on both positives
#5 is your switch ground
Old Oct 1, 2008 | 11:45 AM
fryguy190's Avatar
Default Re: (IB4TL FTW)
o yea ur right. i didnt look at it close enough...
number 2 is gona go to the fuse box and 4 needs to hook up to a constant +power.
Old Oct 1, 2008 | 01:42 PM
jdmcivic1's Avatar
this is for EG though. it might help.
http://www.teknotik.com/jdmrid...ights
Old Oct 1, 2008 | 09:05 PM
EK_kidd's Avatar
Default Re: (fryguy190)
Wait so what's this I keep hearing about a male connector rapped in blue tape? Leave that alone?
Old Oct 2, 2008 | 06:42 AM
EK_kidd's Avatar
Default Re: (EK_kidd)
Old Oct 2, 2008 | 08:58 AM
IB4TL FTW's Avatar
do you have a male connecotr wrapped in blue tape? where is it located in the circuit? Usuall for fog lights for every A there is a B... fog lights run on a circular(continuos) so everything is closed
Old Oct 2, 2008 | 10:15 AM
TehMan's Avatar
"they're" for the thread title
Old Oct 2, 2008 | 09:14 PM
EK_kidd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IB4TL FTW &raquo;</TD></TR><TR><TD CLASS="quote">do you have a male connecotr wrapped in blue tape? where is it located in the circuit? Usuall for fog lights for every A there is a B... fog lights run on a circular(continuos) so everything is closed</TD></TR></TABLE>
its a male connector wrapped in blue tape right of the fuse box.
Old Oct 2, 2008 | 09:19 PM
jasony0630's Avatar
76.26.106.124
Well I have a couple of questions to ask you. It has nothing to do with the current topic.
So how in the world do you pull bitches with a civic?
Do you pop your collar and tell them you're hot ****?
Do you tell them that you have a huge mansion and you needed 35 miles per gallon?
Wtf?
Maybe it's where you live....
Because the women here don't like slow cars.
Old Oct 2, 2008 | 11:53 PM
sageuvagony's Avatar
Default Re: (TehMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMan &raquo;</TD></TR><TR><TD CLASS="quote">"they're" for the thread title</TD></TR></TABLE>
LOL!!!! Some of these grammatical errors make us twitch
Old Oct 3, 2008 | 02:05 AM
b16_sol_707's Avatar
here's the instructions for wiring them up with the password fog light kit: http://www.passwordjdm.com/Ins...s.pdf
You should be able to use that and adapt your kit accordingly.
Old Oct 3, 2008 | 03:59 AM
chickenwing's Avatar
Default Re: (b16_sol_707)
if you are having so much issues figuring what the wires go.
i highly suggest you take it to a pro and pay the price.
making wrong connections and burning things is gonna be more costly.
Old Oct 4, 2008 | 07:16 AM
jasony0630's Avatar
76.26.106.124
you fail.
Wiring foglights is about as easy as building a motor.
No seriously, it is.
All you gotta do is google that ****. For the foglights atleast. With motors (any damn motor), you just gotta make sure your clearances and torque specs are correct.
There's not much to it.
So unless you're a dumb *** [freak], I'm pretty sure you can take on this "little" task. But I did say "Unless you're a dumb *** [freak]..."
So IDK.
Old Oct 4, 2008 | 07:27 AM
sde780's Avatar
Default Re: (jasony0630)
FIRST google result has clear instructions on how to wire it
http://www.clubcivic.com/board...66852
Old Oct 4, 2008 | 07:31 AM
jasony0630's Avatar
76.26.106.124
EXACTLY!
Goddamn, the OP should be giving you dome right now for finding it for him.
Old Oct 4, 2008 | 08:48 AM
EK_kidd's Avatar
There are some instructions floating around the internet that tell you how to install genuine Honda fog lights. Those will tell you how to do most of the work for the OEM-style ones too. I recommend using them as far as you can. Their usefulness ends, however, when you get to the inside wiring harness. Ebay harnesses are different from OEM Honda ones. (With stock fogs, the system turns your fog lights off when your high beams are on. This is not so with Ebay fogs.)
i found out how to do them.. the links ppl where sending me from b4 was for the OEM fog lights.. the rely harness i have is different from the OEM.
thanks anyways.. and good link btw
Old Oct 11, 2008 | 04:22 PM
EK_kidd's Avatar
thanks for the help ppls!!!!
some pics
Old Oct 12, 2008 | 01:39 AM
jasony0630's Avatar
76.26.106.124
looks good.
But are you going to:
1. Paint your grille
2. Paint your lip
3. Fix that huge gap between your grille and bumper
4. Fix the huge gaps between the hood and bumper
Old Oct 12, 2008 | 03:05 PM
EK_kidd's Avatar
Naw I don't think I'm going to paint the grill or lip any time soon... maybe when I repaint the whole car.. Like a darker gray.. And for the gaps I'm getting to that.. I just don't have time to do it.. I guess when I I finish buying all my parts to boost the car. Then I will fix those gaps.. If u notice the right lid for the fog light kinda sticks out. The car has been in a crash b4 from the last owner.
Old Oct 12, 2008 | 09:23 PM
jasony0630's Avatar
76.26.106.124
Sucks man.
Cuz that car will definitely look a lot better from the front without those gaps.
But your car would look better anyway with a huge front mount.
Good luck.
Old Oct 13, 2008 | 02:24 AM
is that your camera or do i see alot of glare?
Old Oct 13, 2008 | 01:24 PM
EK_kidd's Avatar
Default Re: (chickenwing)
I took the pics from my Sidekick LX.
smackdown
Mar 10, 2010 11:48 PM
jiro
Honda Civic (2006 - 2015)
Jun 24, 2009 09:11 AM
fwdftw
10
Jul 24, 2006 05:31 PM
EM1VtecSi
Feb 28, 2005 07:11 PM
chief_rucka
Oct 21, 2002 11:49 AM
