ah oh! 2 Ohm on primary distributor coil
I have measured with an Multimeter the ignitor coil. Users manual says 0.6 - 0.8 Ohm for the primary and 14 - 18kOhm for the secondary.
The secondary is with 16kOHM within spec, but the primary with 2 Ohm is way outer spec. I think I have located the problem.
Tomorrow is race time and I still have no distributor or coil.
You are seeing the resistance of the leads of the ohmmeter. The leads themselves have anywhere from .5 to 1 ohm of resistance. That's definitely not your problem.
AndyD
Dec 22, 2014 03:13 PM
