main relay
Old Sep 30, 2008 | 09:14 PM
classdork987654's Avatar
Default main relay
i have a 91 hatch and am having starting problems. it starts fine when i first drive it in the day then if i have drove for a while or let it sit it wont start. everything seems to work and turn over and using staring fluid will start it but then it dies? could this be the main relay? thanks im a noob
Old Sep 30, 2008 | 09:33 PM
89s1's Avatar
Default Re: main relay (classdork987654)
100% sounds like a main relay.
I've changed it twice, and the hardest part is getting the mounting bolt back in.
I even made my wife try with her smaller fingers. Eventually I caved and pulled a bolt from the dash to free up another inch of room. just enough to get it with my tongue stuck out the right way.
If you remove the coin tray its right there staring you in the face.
If you do a search there is a thread about repairing them I remember seeing one time. If you're handy with a sauldering iron it may just be right up your alley.
Old Oct 1, 2008 | 04:37 AM
thank you very much i will try my new relay
Old Oct 1, 2008 | 07:45 AM
90_EX_Civic's Avatar
Default Re: main relay (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">
If you do a search there is a thread about repairing them I remember seeing one time. If you're handy with a sauldering iron it may just be right up your alley. </TD></TR></TABLE>
oh really, i have two extra ones that don't seem to work right. must search now, and thanks.
Old Oct 1, 2008 | 08:18 AM
saka's Avatar
"Eventually I caved and pulled a bolt from the dash to free up another inch of room."
i just did this the past weekend... from searching the site.
remove fuse cover
remove coin holder
unscrew hood latch
when you have the door open, there a vent that goes through the door.
take out the vent cover and you will find the dash bolt that will free up another inch.
thats it... no more stranded ef.
Old Oct 1, 2008 | 10:20 AM
89s1's Avatar
Default Re: main relay (saka)
thats a lot of work....
I pulled the hood latch the first time i did it, just b/c i wanted the whole area cleared out so the realy was on a platter.
Once i had done it already i just left the hood latch in and did the "more swearing" technique for the second time.
Old Oct 1, 2008 | 01:11 PM
Pee Wee's Avatar
on a side note, always try soldering the old one before buying a new one, because it almost always fixes it
nismogrendel
Apr 24, 2010 01:43 AM
Mr.Smog
Aug 15, 2006 11:13 AM
DirtyBirdJR
Aug 29, 2005 02:59 PM
91d15bvtec
Jun 27, 2005 06:35 PM
4doorH22
Apr 16, 2002 07:16 AM
