Setting Timing
Ok, this may be a dumb question, but I was told I need to get a timing cover in order to set timing on my B20 (water pump and timing belt replacement). Can it be done without this timing cover as I never received one when I bought the motor?
The old belt was already removed during B16 head install. Block is all stock w/ stock B16 head, with a OEM timing belt and water pump going on it.
On the lower timingbelt cover there is a line that points at the crankpulley, so if u use a timing light to set timing the line should point at the middle mark on the crank pulley when the car is at idle. Hope that helps
Dan in Japan
May 20, 2008 06:33 PM
