motor work
Old Sep 30, 2008 | 07:02 PM
KDvtec5757's Avatar
Default motor work
hey guys i have a 91 CRX hf with a JDM b16 motor is all stock right now but im get ready to start buying thing i what to go NA but do not no what cams to go with need some help but here is the list that i have got and some things that i still need to get if you can think of any thing you would do diff let me no or any thing im missing let me no but big help on some good cams there are to meany out there for me to no whats going to be go
JDM B16A
hasport mounts
CP 12.5 compressio pistons
Toda adjustable cam gears
Skunk2 valvesprings
Password JDM carbon air intake
BDL 68mm throttle body
Blox intake man
BDL fuel rail
BDL fuel regulator
BDL fuel filter
B&M fuel gauge
Old Oct 2, 2008 | 09:20 AM
00b20vtecoupe's Avatar
Default Re: motor work (KDvtec5757)
walbro fuel pump, s2 retainers and s2 cams, rods? rod bolts, injectors, a good header... a p28 chipped with some hondata or sumthing to tune it. and fitting all of wat u just saif in 1 sentence is very confusing but i would suggest swapping ur block out to sumthing bigger or sleeving it to a bigger bore.
Old Oct 2, 2008 | 09:37 AM
projectcivicjp's Avatar
Default Re: motor work (00b20vtecoupe)
like b20vtec coupe said, get a bigger bottom end or sleeve the b16. i would say no on the PW JDM CF intake. i have one and it made no power on the dyno. get a 3" intake pipe and a velocity stack with the filter. I would go with S2 adj cam gears, (price wise) some Blox Type B cams or some HSL's. ARP rod bolts, I would not go with a hytech replica header style for that size block. if you upgrade then yea but if you stay with the b16 block i would say a nice JDM ITR header or something like that.Aslo Port and Polish the head. everything else looks good
AdrianArteaga98
20
Apr 17, 2017 06:54 PM
bigchili
Feb 17, 2011 12:29 PM
killerpenguin21
Aug 7, 2008 11:16 AM
Beau Gotti
Oct 11, 2006 03:41 AM
JDMvtecDRAGSTA
Jul 16, 2002 04:59 PM
